      10-25-2009, 11:24 AM   #1
rcodea
Drives: 19 M2C
code P2096?!...ESS and RPI mods, still there!
while cruising from Columbia to Charlotte last night for the 'Shinedown' concert, light kicked on. the pocked scanner shows code P2096; 'lean post cat'. mod list is below. no performance change noticed
ESS flash with the catless/header/o2 delete and exhaust option
stock cats/header still installed
RPI scoop/filter installed after flash
RPI axleback exhaust after flash
car is a '06 Z4MR with 74k miles(first owner put ~70k in just 18 months). I know that the vavles need to be adjusted, along with the inspection2 and wheel alignment.
i have had no issues with the car, minus this code.
any ideas? thoughts?
~Ryan
      10-25-2009, 08:25 PM   #2
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
That's an O2 sensor issue, whatever you're using to turn off the catless code is not working properly, or needs to be adjusted.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      10-26-2009, 05:14 AM   #3
rcodea
Drives: 19 M2C
i have nothing to trun off the catless code...all cats and O2 sensors are installed and working.
~Ryan
      10-26-2009, 10:42 AM   #4
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
P2096(post catalyst fuel trim system too lean bank 1)
It could be a few things. A bad or dirty MAF or intake turbulence issue from non OEM intake or Bad secondary O2 sensor.
      10-26-2009, 12:10 PM   #5
rcodea
Drives: 19 M2C
no issue then with the flash and keeping the headers/cats/O2 sensors?
i'll look into cleaning the MAF. any way to trouble shoot for a bad MAF? possibly bechcheck for resistances?
Intake is OEM, minus the scoop and filter. I have not read any such issues using these parts together.
anyone know of a way to troubleshoot for a possible bad secondary O2? given the flash, can i just disconect secondary O2 and forget about it?
~Ryan
      10-26-2009, 02:32 PM   #6
sales@ESSTuning
391
Drives: ESS M3 / M4
~Ryan
Ryan
Try to clean off the MAF with CFR MAF cleaner and have the code cleared. This is most likely your issue and the code should stay off. You do not want to disconect the 02 sensors.
      10-26-2009, 05:01 PM   #7
DarkstarZero
DarkstarZero's Avatar
Drives: Daytona 95 M3, X7 M50, e92 M3,
I had a similar problem on my old 95 M3. Some reading would go outside the levels the computer wants to see for just a short period of time and it would throw the O2 sensor error. Even after the reading returns to normal the Check Engine light stays on until after so many cold restarts, then it turns off. I didn't invest any time in it because it only came on every other month and was on for just a few days.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center!
Enter Referral ID: 420186
      10-26-2009, 07:25 PM   #8
rcodea
Drives: 19 M2C
thanks guys, i'll try it out and report results.
~Ryan
      11-02-2009, 03:45 PM   #9
Z-Four
Drives: Z4 3.0i
Just FYI, I have headers no cats in my car and until I put my o2 sim in I was getting p2096 and p2098 as well as the catalyst inefficiency codes. The only way I was able to clear those codes (p2096 & p2098) was to do a full adaptations reset or else they would just come back after exactly two driving sessions. It took me a good two weeks of wondering why my o2 sim wasn't working until l discovered that. So even if you have your DME re flashed to disregard your rear o2's you may still need to have your adaptions reset untill those codes will go away.
      11-02-2009, 03:56 PM   #10
JCz04Bimmer
JCz04Bimmer's Avatar
32
Drives: 06 Z4MC
Good advise. Pulling the battery connections for 15 minutes should reset most adaptations and will allow you ECU to adjust more airflow across the MAF. That said, that pesky MAF is finicky as hell. Be VERY careful removing and installing it for cleaning. I've definitely broken one just trying to clean it and it ain't cheap...
      11-02-2009, 05:05 PM   #11
Z-Four
Drives: Z4 3.0i
Unfortunately disconnecting the battery will not reset adaptation values in the DME. It has to be done with a scan tool capable of communicating with the DME on a dealer level. I really wish it was as easy as disconnecting the battery
      11-04-2009, 09:27 PM   #12
rcodea
Drives: 19 M2C
ok, so after cleaning the MAF, and driving it, the code cleared without going to the dealer.
It came back tonight; 55mph, 2400rpm, 5th gear on a level road.
i'll try cleaning it again. next will be the dealer to have the adaptions reset completely reset. any other ideas?
i am not familure with the adaptation values issue, do i need to tell the dealer something specific to get them cleared? is there anyone else that can do this asside from the dealer...not a big fan of my dealer!
~Ryan
      11-08-2009, 07:06 PM   #13
rcodea
Drives: 19 M2C
CODES ARE BACK!
now throwing a 'p2098' and 'p0041' for codes...both pointing again to the second bank O2 sensor.
since the 'p2096', i did the following
-cleaned MAF using MAF cleaner spray
-dealer did vavle adjustment
-dealer cleared the adaptive values
-dealer cleared the 'p2096' code
-dealer did oil change
i have put ~100 miles on the car since the dealer performed the above
the code keeps throwing while cruising, not when driving aggressively or around town.
any other ideas guys?
~Ryan
      11-09-2009, 08:23 AM   #14
O-cha
O-cha's Avatar
218
Drives: Mcoupe
It absolutely does not, I can read the adaptions and tell you this with certainty.
      11-09-2009, 09:50 AM   #15
laidback
Drives: M's
Did you change your O2 sensors? if not...time for a replacement
CODES ARE BACK!
~Ryan
Live as if you will die tomorrow, but learn as if you will live forever." M.G
<img src=http://i251.photobucket.com/albums/gg289/l8dback/2012/ff8d7019.png border=0 alt= />
      11-09-2009, 01:10 PM   #16
rcodea
Drives: 19 M2C
i had the p2098 and p0041 cleared last night using a handheld from the local parts store(i pushed the buttons of course). put 45 miles on it since, no other lights yet, but i expect they will come back tonight.
thats what i am thinking, but wanted to make sure there was not something i can do to troubleshoot them first. additionally, which ones do i need to replace? here is the realOEM.com link to the header sensors....
http://www.realoem.com/bmw/showparts...64&hg=18&fg=10
~Ryan
      03-30-2010, 04:12 PM   #17
kav
Drives: Z4M
Any updates on this?
      05-21-2010, 07:06 PM   #18
rcodea
Drives: 19 M2C
had to replace the sensors(all 4) and reset the adaption codes too. all is well now.
~Ryan
      05-21-2010, 08:12 PM   #19
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
Is it possible to pass a california emissions test with headers and ess tune?
2011 X5 5.0 Dinan - SOLD
2007 Imola Red Z4 M Coupe -SOLD
2004 Navy Blue BMW 325Ci
      05-22-2010, 09:05 AM   #20
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
I'd say it would be really difficult.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      05-22-2010, 10:22 AM   #21
Getssum96
Drives: TBD
Care to elaborate on this? ^^^^^
Most cars with Headers run cleaner than stock, and the ess tune isn't a "Dirty" one from what I understand.
Most smog tech have NO idea what they're looking for, except the obvious ones!
Most have NEVER seen our cars so ???
      05-22-2010, 02:07 PM   #22
fatmatt0116
Hooligan
I think even with the ESS fix the computer still throws a code which gets read by the computer when you take it in for inspection. Is there any way around this?
