      07-15-2015, 09:02 AM   #1
rsutoratosu
Drives: Z4 3.0i
"Charging" the key fob
So before I tear it down and replace the key fob battery or something, I thought I should try to recharge the key.
Does the car actually need to be on or can you plug it into and turn it on to accessory mode ?
My thought is if i'm unable to charge it, with the tender on, I can leave the key in the car and let it charge in accessory mode without turning the engine on.
Any ideas ?
-Roranji
      07-15-2015, 10:00 AM   #2
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
Any ideas ?
The manual does say the car needs to be driven to recharge the key, and that you only need to drive with the key at least twice a year to keep it recharged. I'm not sure if leaving it in ACC mode would help.
Have you tried reprogramming your keys yet? When I bought my car one of the keys didn't work. I thought it was a battery issue, but it turns out I only needed to reprogram it. Try this before tearing apart the key.
2008 Z4 3.0si Coupe
      07-15-2015, 10:43 AM   #3
rsutoratosu
Drives: Z4 3.0i
both key works its just one key needs to be like 2 ft away to lock and unlock, the other works like 30ft away. I figure ill test it, i left it in acc mode and ill test it later today to see if the distance is better or not.
I have the car on tender in garage so doesn't hurt to try..
-Roranji
      07-15-2015, 12:13 PM   #4
Kimo
Drives: E31 E90 F25 MCS
Touch the tip of the "dying" key to your chin, then press the lock or unlock button. Range will increase by 5X - guaranteed.
This is an interim step (assuming you don't mind looking like an idiot) before digging deep for a new key. I'm totally serious.
      07-15-2015, 12:56 PM   #5
koruptor
koruptor's Avatar
31
I've tried this and it actually works. My keys don't work further than 10 feet otherwise.
2008 Z4 3.0si Coupe
      07-15-2015, 02:28 PM   #6
rsutoratosu
Drives: Z4 3.0i
I been trying that trick for a while.. doesn't seem to work for me. Its weird, sometimes I can unlock my car like 50ft away, some days, i can be right in front of it, 3 inches away and buttons wont do anything
-Roranji
      07-15-2015, 09:16 PM   #7
wonton180
wonton180's Avatar
Drives: 07 Z4MC
I have the same problem. can we simply replace the batteries in the key fobs or is opening them rather destructive?
      07-15-2015, 09:28 PM   #8
chickdr
Drives: 2006 M Roadster
They can be replaced("simply" isn't the term I would use though). Too bad they didn't just design it to be replaced periodically.
      07-16-2015, 10:04 AM   #9
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Apple's current iPhone battery engineering department all started in the BMW key battery engineering department.
      07-19-2015, 03:03 PM   #10
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
Thanks for the reminder. My spare has been sitting in a drawer for years. I need to switch my daily key ASAP.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      07-19-2015, 11:33 PM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
I switch mine once a month, round about the first of the month.
      07-20-2015, 08:45 AM   #12
David70
Anytime something needed long term that is powered by a battery and the battery can't be replaced easily means the design was poor. Every rechargeable battery eventually needs to be replaced and I don't want to buy a new key/remote because the battery finally expired.
      07-27-2015, 01:52 PM   #13
rsutoratosu
Drives: Z4 3.0i
My car is still garaged... I have a minivan in drive way and a suv, so z4 never sees day light.. sad sad year...
-Roranji
      07-27-2015, 01:55 PM   #14
Twixboy
Drives: '04 Z4 3.0i 6spd
Huh? No sun in Chicago yet? And I thought I was bad, only driving the Z4 2-3 days a week on a good week. Most weeks I only drive it once because there is always a 20% chance of thunderstorms (I leave it in the garage on those days).
      07-27-2015, 09:55 PM   #15
SD ///M4
///Multiple
SD ///M4's Avatar
It works even better if you hold your key to your temple. Jeremy Clarkson demonstrates it here:
There's another video by a British scientist who demonstrates the phenomenon which is essentially using the large mass of liquid in your brain to amplify the signal. It even works using a gallon of water instead of your head. Edit: found it:
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      08-01-2015, 03:03 PM   #16
rsutoratosu
Drives: Z4 3.0i
Shoot, i should update my profile, im in the north east now. And around march of this year, they grind down a major section of the I95 in new england, around 10-15 mile of the highway and have not repave it yet.. There are still tons of large pot holes.. i rather not take the risk of even driving it...
-Roranji
