      06-12-2012, 02:45 PM   #1
Beedub
02 sensor done.... a lil help here please.
ok so im getting a CEL, shows as p0141, this is 02 sensor heater circuit malfunction bank 1 sensor 2.
now bank 1 is cylinders 1 -2-3 im trying to work out which one of the POST cat sensors this is , drivers side or passenger side, bearing in mind im a uk car so RHD, am i right in thinking drivers side?? i cant get to the car to check can someone confirm for me please so i can order this unit :-)
thankyou :-)
      06-12-2012, 06:26 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
this will help with part numbers so you can order the right one, and then you can check the connector on it since they're all different IIRC
http://www.pelicanparts.com/bmw/cata..._pg2.htm#item9
