      11-19-2015, 03:05 PM   #1
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Soft Top part removal help
Can't seem to find any information on the "windshield frame cover" removal (part# 54317056282). It's the plastic piece/cover at the inside front on the soft top that has a removable part to allow access to the motor. Two pics attached.
The part screws into the top at the front with 4 bolts, with one additional bolt inside the removable motor cover. What I can't tell is how the back attaches. Is it clipped on? Close-ups of the part on ECS show what looks like possible clip attachment points. The plastic has broken in a few places and I'd like to replace this part myself. Thanks for any experience you may have with this!
John
      11-19-2015, 06:23 PM   #2
antennahead
I have since discovered that there are two hidden screws, one on each side that have to be removed. I think it may come off after that....... still wondering if the liner is attached in any way to this part.
      11-19-2015, 07:50 PM   #3
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
It will. I just replaced mine a couple weeks ago. Once you take out the screws across the front, the ones on each side and the one in the cubby hole in the center, it should drop down. Then you'll see a series of small screws that hold the head liner to it. Once you have the screws out there's a plastic strip attached to the head liner that snaps into the center and the ends of of the trim piece and once you manipulate it out the piece comes free. Installation of the new piece is just the reverse.
Top Down 365
      11-19-2015, 10:53 PM   #4
antennahead
Thank you good Sir, you are a gentleman and a scholar
