      04-19-2012, 01:48 PM   #331
Rekla
Hug the road... Carpe Asphalt
Rekla's Avatar
Drives: 2007 ///M Coupe
What is the easiest way to attach this front lip permanently? Remove the front bumper from the car, bolt the front lip spoiler underneath and install the front bumber back onto the car? I have one of these MSTACHE laying around, but have yet to install it...
2007 BMW ///M Coupe
      04-19-2012, 02:16 PM   #332
ricanbandit
ricanbandit's Avatar
29
Drives: 2011 30i
having done it, I will will be doing the following after I repair and paint it.
i will lift the car, put it on jacks. get a heat gun heat the double side tape. Affix the tape to the MStache, then heat the double side tape on the other side then affix to the car. then bolt on firmly.
Hope fully this will end up better than my previous attempt
2011 30i
[SIGPIC]/SIGPIC]
      04-19-2012, 05:59 PM   #333
Composite Steve
Drives: 03 330i ZHP, 73 Mini, 74 914
Originally Posted by nesrevival View Post
Steve, Can you remove me from the list?
I didn't know there were no holes on spoiler
thx.
Sure, but if you'd like, I can drill the holes for you in advance.
There's no need to remove the front bumper for the installation.
I use the 4 factory screws and then 3M double sided automotive molding tape such as this http://www.sears.com/shc/s/p_10153_1...=SPM5901845408
Make sure the mounting surfaces are clean and that the ambient temperature is warm enough for the tape adhesive to set and you're good to go.
The Mstache won't go anywhere if installed properly.
Sorry for your misfortune. I'll PM you some tips to fix it.
Thanks,
Steve
      04-22-2012, 11:32 AM   #334
ricanbandit
29
Drives: 2011 30i
Well got it done. I uised the glazing putty, sanded and used some black glossy metallic paint and well this is how it turned out. I think it came out pretty good. Thanks for the advice on how to "fix" it Steve
Also. I used some transparent heat/freeze/waterproof silicone in the small gap, just to make sure that water etc doesn't get to the tape. But all in all I think it came out pretty good
2011 30i
[SIGPIC]/SIGPIC]
      04-23-2012, 10:17 AM   #335
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
2020 Z4 M4.0i  [5.00]
It looks good from here, very nice look, I can't wait to get mine installed.
Regards
2013 335is E93
2018 X5 35d
BMWCCA / ZSCCA Member
      04-24-2012, 03:51 PM   #336
Composite Steve
Glad to see it back on the car.
      05-06-2012, 09:14 PM   #337
mexicobmw
Mexico
56
Drives: car
Hello, I love the Mstache!!! is there a CF version. (with pre drilled holes)
regards and could you put the 3m tape before shipping it out. Im in mexico and it is hard to source the tape here.
thanks
diego
      05-07-2012, 03:54 AM   #338
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
Finished and installed.
Bruce came up with support clamps on the front. We used 2 screws per side, three clamps in the middle and the double tape across the whole thing. It ain't coming off unless it gets ripped off.
2013 335is E93
2018 X5 35d
      05-07-2012, 03:58 AM   #339
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
Here are the clips he came up with. Short pieces of aluminum bent slightly in the middle to give a piniching effect once screwed in place.
2013 335is E93
2018 X5 35d
      05-07-2012, 03:59 AM   #340
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
The clip reaches up under the lip and holds it in place using the exsisting screw hole. No new holes to drill in the bumper.
2013 335is E93
2018 X5 35d
      05-07-2012, 04:01 AM   #341
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
The black on the red makes it really pop out at you. I love it on my car, but it looks even better on the red.
2013 335is E93
2018 X5 35d
      05-07-2012, 12:53 PM   #342
Composite Steve
You're right, black on red makes everything stand out. Love it!
Great ingenuity with the brackets
Steve
      05-07-2012, 06:35 PM   #343
trialskid
Drives: 08 335i
Can we still get these
      05-07-2012, 06:37 PM   #344
markZ4MC
Drives: Z4MC
I'm interested in one as well. PM me if someone is selling theirs...
      05-07-2012, 08:00 PM   #345
johanness
Drives: 2008 Z4MC
When will the lower profile units be available?
      05-07-2012, 08:10 PM   #346
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
The bolt for the mounting plates looks too large. I don't want to enlarge the existing hole in case you want to revert back. Did you have to use a different clip?
      05-07-2012, 08:30 PM   #347
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
more info on this please
instagram: @ dubsesd
      05-07-2012, 08:50 PM   #348
mexicobmw
Mexico
56
Drives: car
subscribed on the lower profile unit and if a cf version comes out better!. (was about to pull the trigger on the regular version).
regards
diego
      05-08-2012, 08:41 AM   #349
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
That is the existing fastener from the car, not a new bolt. Bruce did not have his apron attached under the car so we could do the work and reach up behind the bumper if we needed to. But that screw and 3 more like it hold the front of your apron on under the car.
No holes were enlarged to accomidate any new size screws. Bruce matched up his two outside holes and used same size screws. I matched up 1 each of the far outside holes but afte we got it up I simply shot a screw threw the bottom of the bumper in the meat of the mustache. There is no reqiurement to really match the holes if you don't want too. You can not see any of the fasteners once installed.
2013 335is E93
2018 X5 35d
      05-08-2012, 08:02 PM   #350
RobMCoupe
RobMCoupe's Avatar
60
You can see mines are small screws attaching the spoiler and undertray.
      05-09-2012, 08:07 AM   #351
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 2013 335is
It looks like to me someone has already substituted the original screws for those. They are not the same. You should have the hex washer type b screw like on our cars. They are all over mine, so unless BMW decided to change up screws on the underside apron someone did that for you.
In any case more than likely the body of the screws are the same size, our screws just look bigger because of the head and washer combination.
EOS.
2013 335is E93
2018 X5 35d
      05-09-2012, 09:14 AM   #352
RobMCoupe
RobMCoupe's Avatar
60
EOS.
Real OEM have screws like in my picture. Just saying there are differences so the bracket might not work on all.
