      04-03-2020, 11:51 AM   #155
Steeler
Steeler's Avatar
2429
Originally Posted by Hullbilly View Post
Hi All,
Sorry if this question has been asked already, I've read the whole thread and cant find a definative answer;
I have an '03 Z4 3.0 auto without the sports button, I haven't gone rummerging around in the centre console looking for the white connector yet. But I did read that when the button is pressed people say that 'SD' appears on the dash, this also happens when you shift the auto gear lever to the left, is this not the same mode or does the sport button add another dimension to the throttle control?
Thanks in advance
Try this thread for info
https://www.zpost.com/forums/showthread.php?t=1703579
      04-06-2020, 12:06 PM   #156
Terraphantm
Drives: E46 M3 Coupe
Hi All,
Thanks in advance
The sport button alters the throttle map, stiffens the steering, and puts the transmission in sport mode. It may also make transmission shifts in manual mode somewhat quicker (this is definitely the case on newer BMWs, not sure about the e85)
      07-21-2021, 10:40 AM   #157
ggeerinckx
Drives: BMW Z4 coupe 3.0si
Sport button for exhaust valve
Hi - I'm getting a cutout valve with a remote. I'd like the sport button to serve as the switch for the valve rather than the remote. Is that possible?
      01-11-2023, 01:51 PM   #158
rooslawn
Drives: 2005 BMW Z4
Hello Chuck, I know I'm reviving an age old thread. Hopefully you see this post. You said that you found someone who can generate a new data file. Can you please share who you contacted about that? Thanks in advance! Russ
