      11-18-2015, 06:28 PM   #1
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Soft Top slam when closing
I know I've read about this somewhere on the site, but my searches didn't reveal anything. When I close the top it is slamming hard on the top of the windshield frame where it locks. Isn't there a tension cable that can be adjusted that sets the top down easy when it reaches the end of the closing procedure? Thanks for any information you have on this.
John
      11-18-2015, 07:16 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I think they're 2 elastic bands that are probably stretched or broken.
I have the same problem, and toyed with the idea of replacing them.
I decided it's cheaper and easier just to put my hand up and set the top down gently.
http://www.zpost.com/forums/showthread.php?t=753458
      11-18-2015, 07:48 PM   #3
antennahead
Thanks for the link! The slamming has caused part # 25 here:
http://www.realoem.com/bmw/enUS/show...diagId=54_0310
...... the plastic piece at the front of the top to split around one securing screw and the section that the motor cover snaps into has broken completely. I glued the broken piece back together last night and it's holding. I too am stopping the close procedure near the end and then easing it down to avoid any more damage. That above part is now $200 at ECS
I also just had my passenger airbag occupancy sensor go out...... irritating
