08-19-2010, 11:29 PM | #1 |
Rep 1,143
To Techron or not to Techron
I was considering running some BMW Fuel Additive/Techron in my car and was wondering about what others more knowledgeable than myself thought of the subject.
Since I bought the car I run exclusively Shell V-Power 93 octane as an approved Top Tier Gas. However, who knows what the previous owner used for the first 15,500 miles? I don't think I'm experiencing any issues with the car, necessarily. However, since it is a used car, I guess I won't really know if I'm running at, say 90-95% rather than 100% since I didn't experience this car when it was brand new. My fuel economy appears to be subpar, but that's about the only quantifiable difference I can detect between my car and some others'. Even then, there are a lot of other variables at play. Another thing I've noticed is that sometimes I get a bit of that that metallic, reedy sound from the engine, and sometimes I don't, but from what I understand that seems to be a normal effect of the VANOS. I guess the inconsistency is the only thing that makes me wonder. It almost feels like my engine is running "smoother" when I don't get that sound. Anyway, I guess this is a long way of asking: do I stand to do harm by using fuel cleaner unnecessarily? Would it be safer just to let the Shell gas do its work over the long run, or might a concentrated dose of fuel cleaner help clear out whatever deposits might have accumulated from before as a more or less preventative measure? |
08-20-2010, 07:50 AM | #2 |
Imola Lover
26
Rep 749
BMW puts out a new TSB every couple years as a reminder that essentially says the same thing:
Use Top Tier Gas. In Lieu of Top Tier Gas, supplement with Techron (BMW private labels the stuff). It's ok to use Techron even with Top Tier Gas but not required. I ran a bottle of Techron through every 3k miles.
08-20-2010, 09:25 AM | #3 |
Bad Lieutenant
233
Rep 3,517
I have done this maintenance once per year, and haven't found nearly the particles this older engine has had, but may be really cheap to do if you are thinking VANOS related issues could be at hand:
http://www.m3forum.net/m3forum/showthread.php?t=225780 Other than that, I run the concentrate in 10oz in two consecutive tanks about twice per year, doesn't seem to hurt and it's inexpensive.
08-20-2010, 10:03 AM | #4 |
Rep 1,546
is there a list of what is considered top tier gas? I'm running the local stuff 91 octane. I don't eeally have much of a choice. I ran a bottle of Techron through in my first tank just in case, because like OP, i didn't know what had been run the last 30K miles...
am i harming anything but not consistently running top tier gas?
08-20-2010, 10:08 AM | #5 |
Rep 1,991
08-20-2010, 10:28 AM | #6 |
Rep 1,546
makes sense...thanks.
i'm doing a little research on what Town & Country uses, since that's like 90% of what's available here...anyone form Texas know?
08-20-2010, 12:12 PM | #7 |
Rep 6,863
I dont really buy into the whole top-tier gas thing. Ive been using a combination of a whole bunch of different brands for years and never had a single problem. I know many people prefer shell but all the shell stations around me are always significantly more expensive than other brands. I usually go to Hess as they seem to be the cheapest. 93 octane is 93 octane as far as I can tell.
08-20-2010, 01:22 PM | #8 | |
Rep 12,565
08-20-2010, 02:47 PM | #9 |
Rep 576
Drives: Interlagos Z4 M Coupe
Never knew about Top Tier.. I never go to BP, Mobil, Exxon or Citgo for political/humanitarian reasons and now I guess since Gulf and Hess aren't on the list I'll probably primarily be frequenting Shell
08-21-2010, 12:33 PM | #10 |
Rep 12,565
don't see that logic considering most gas stations are privately owned by your avg joe
08-23-2010, 10:43 PM | #11 |
Turd in the Punch Bowl
19
Rep 239
I am thinking about checking that stuff out.. It isn't going to hurt anything.. I just don't know if the previous owner used crappy gas for 18,000 miles?? All I know is that she gets V-Power now...
08-24-2010, 09:18 AM | #12 |
Rep 1,772
Drives: 2007 Z4M Coupe
Hate to break it to you man, but they are all evil. BP just happened to be caught here doing what all of them do often.
08-24-2010, 10:49 AM | #13 |
Imola Lover
26
Rep 749
It's not going to hurt anything.
08-24-2010, 03:24 PM | #14 |
Rep 1,143
Only reason I asked was based on some conflicting opinions in this thread: http://www.xoutpost.com/bmw-sav-foru...techron-3.html
If I do use it, should I avoid having it sit in the fuel system for too long? Would it be ideal to do this say, on a fill up before a road trip? |
08-24-2010, 03:51 PM | #15 | |
Imola Lover
26
Rep 749
08-24-2010, 03:54 PM | #16 |
Imola Lover
26
Rep 749
Oh and you should be more worried about ethanol in your fuel and its shelf life as compared to Techron.
