      04-03-2023, 03:09 PM   #177
wdb
dances with roads
wdb's Avatar
4732
Originally Posted by 86Zed View Post
How well does this work with an electric pressure washer (if you know)? Been looking for a good solution for the underside
I use it with my electric, which I also really like.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
86Zed932.00
      04-05-2023, 03:37 PM   #178
TyzToyz
TyzToyz's Avatar
Drives: 2008 BMW Z4 3.0si
Great Work! I have followed this the whole way.
I am wondering if you have a preferred brand of foam for the cannon, or is it like any other soap for washing a car (personal preference)?
Not sure if it makes a difference, but I had the paint corrected and ceramic coated last year.
Tye
      04-06-2023, 05:07 AM   #179
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Tye
Thanks, I was using Adams strip wash in that photo but any soap designed for a foam cannon is good.
2008 E86 M coupe
      04-19-2023, 07:09 AM   #180
E93Seattle (Racerbruce)
E93Seattle (Racerbruce)'s Avatar
800
Drives: 2013 335is E93 & 2021 X3
well done grannyknot!
this was such a deep-dive i don't know where to begin....incredi-hours and acumen spent to "refresh" this marque -
tell us about the maiden launch and voyage - any special local places you took her? are you keeping her for a bit before moving on to the next challenge?
      04-19-2023, 03:20 PM   #181
grannyknot
grannyknot's Avatar
952
Thank you, no big trips yet, still have a couple of bugs to sort out, some buzzing in the stick shift, could just be the stiffer mounts.
Still have to refill the AC system and get a proper wheel alignment.
Josh at Severn sent me the final Tune to load and just took it out last weekend for a 2 hr. rip to test it out, so much better performance than before.
I don't just mean more power, the consistency, the smoothness, the throttle response all feel better than stock. Just my opinion but the Severn tune is worth every penny, Josh will work with you until you are happy with the results.
It might just be a placebo effect but knowing that every wearable part is now new makes the driving experience more enjoyable. Feels like a new car.
2008 E86 M coupe
      04-19-2023, 04:11 PM   #182
800
thank you grannyknot,
a 2 hr rip is certainly a shakedown....and the increased performance/driveability pegs out the joy-o-meter.
      07-29-2023, 06:21 AM   #183
grannyknot
grannyknot's Avatar
952
The coupe is running very well now, I just found the centre section for the exhaust system on ebay and snapped it up.
I have been looking for this piece since I bought the car, the PO had the original mufflers replaced with Rouge Diablo's which sound great, very happy with them but the hack who did the work cut one of the rear pipes too far back and replaced it with a smaller dia. plain steel pipe.
Also, p/u up a new battery cable with explosive disconnect from one of the members here on the forum. Hoping it will finally fix the airbag warning light.
This is the ebay piece that is on it's way.
2008 E86 M coupe
      07-29-2023, 07:57 AM   #184
2288
Lol that was on my watch list… Surprised it actually sold!
      07-29-2023, 04:44 PM   #185
grannyknot
grannyknot's Avatar
952
I didn't pay his asking price
2008 E86 M coupe
      07-30-2023, 06:22 AM   #186
800
FWIW -
Purchased my 07 Z4MR in early 2010 and immediately installed Rogue Engineering Diablo mufflers - they were still on the car when I sold it in late 2022 and no rust, no fitment issues, no leaks and sounded as good as day one.
      04-21-2024, 12:03 PM   #187
grannyknot
grannyknot's Avatar
952
I replaced the main battery cable with the new one and the irritating airbag light on the instrument cluster is gone, YAY.
But the old one doesn't seem to have any problems that I can find
So there is nothing left to do but try and blow the disconnect charge, anyone know what kind of a signal it requires to set off the fireworks?
I tried 12vdc to the 2 wires coming off the top of the charge but no luck.
2008 E86 M coupe
      04-21-2024, 12:53 PM   #188
maupineda
Drives: E86 Z4MC
Typically, MGG devices require 1.75a of current and 12V for at least 5ms.
Maybe yours is bad and that is the cause of your DTC. There could be something wrong with it internally. you can measure resistance and it should be 2 - 2.2homs. just check resistance on the MGG terminal wires, no need to blow it out just to check if it works, unless you want to do it just for fun.
