      07-08-2014, 01:16 PM   #1
sbottum622
Drives: 2006 BMW Z4 3.0i
Best sound for money?
Whats the cheapest way to get a better growl? Sound generator sadly already gone... 2006 3.0i
      07-08-2014, 01:41 PM   #2
chickdr
Drives: 2006 M Roadster
Either a CAI or exhaust.
      07-08-2014, 02:27 PM   #3
Huz-Z
Huz-Z's Avatar
Buy a big dog.
Huz-Z
      07-09-2014, 09:17 AM   #4
sbottum622
^^^HAHAHA, I'm content with my small dog...
      07-09-2014, 10:58 AM   #5
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
When you say sound generator already gone, do you mean you removed it or that you took out the foam?
      07-09-2014, 11:27 AM   #6
sbottum622
The entire sound generator was removed by a previous owner....
      07-09-2014, 01:30 PM   #7
unluky
unluky's Avatar
7528
That could make a huge difference. I pulled 1 piece of foam (has 2) out of my 04 3.0 Sport sound generator and I was startled by how loud it was. I can't even imagine it with both out. It literally startled me when I nailed it the first time above 4K. I cut the foam piece in 1/2 (I took out the one closest to the cabin and that is the one I cut) and put 1/2 of it back and it is just right for me. Still sounds just the same when poking around, but past 3/4 throttle above 4K rpms and it really growls much more aggressively then stock. People have mentioned it without prompting a few times. Only hear it in the cabin though.
      07-09-2014, 01:31 PM   #8
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
I think you can buy a replacement for around $100, and it's really goddamn loud if you take out the foam pieces. Too loud with both pieces removed, I remember feeling like my windshield was vibrating in my old 3.0. One foam piece removed is just right.
      07-09-2014, 02:19 PM   #9
sbottum622
How hard is it to install?
And what does it actually do?
      07-13-2014, 06:46 AM   #10
m3griff
Drives: Z4 3.0Si
Easy to install. It's basically a plastic pipe that connects the intake with the firewall. It simply transmit sound directly to the cabin. Without the foam it is really loud. But you can move the foam or reduce it to get the level you like. Without the plastic tube there is less noise.
      07-13-2014, 09:32 AM   #11
pelerojo
Drives: '06 Z4M
I do not think my 06 Z4M has one. Anyone know why that is? Do all the other models/years have them?
      07-13-2014, 12:21 PM   #12
unluky
unluky's Avatar
7528
M's do not have them as they growl enough already!
      07-13-2014, 12:25 PM   #13
papak
Drives: 2008 Z4 3.0si Coupe
Is the '08 E86 plumbed the same as the '04? I'd like to try removing some of the foam from the sound generator before I move to exhaust system changes. I see the duct on my firewall but I can't find an expanded diagram online to show the foam insert.
      07-13-2014, 02:10 PM   #14
pungo
pungo's Avatar
I played with removing different foam pieces from the sound generator. In my opinion, it gave more noise, but the noise just made it sound like something was wrong with the car. I tried it for a week and put it back to stock.
I think the best increase in sound (growl) is going to be from an aftermarket exhaust. Sorry, but I don't have any experience with an exhaust for a 3.0.
      07-13-2014, 02:14 PM   #15
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Similar discussion starting here on exhaust options. http://www.zpost.com/forums/showthread.php?t=1009844
      07-13-2014, 03:16 PM   #16
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Not sure why the M doesn't get it from the factory, if it was loud enough as-is then there wouldn't be so many people putting on intakes
Noise is from induction, so adding an exhaust isn't the same. Intake may or may not be louder, but removing the foam is free and takes 2 minutes.
The M has the hole in the firewall for the pipe, they just plug it with a piece of carpeting. It's not hard to install one onto the M, but it's definitely a custom job.
      07-13-2014, 07:06 PM   #17
sbottum622
Does anyone have a link to the part?
      07-13-2014, 07:21 PM   #18
Steeler
Steeler's Avatar
2429
http://www.realoem.com/bmw/showparts...73&hg=13&fg=20
      07-13-2014, 09:09 PM   #19
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
AFE cold air intake. great growl
      07-13-2014, 09:12 PM   #20
papak
Thanks.
      07-13-2014, 09:47 PM   #21
unluky
unluky's Avatar
7528
Super easy, just grab the tube near the firewall and pull it out. Takes a little pulling, but it will come. On mine the grommet came out with it, but it was 10 seconds to put it back in and then the tube just pops right back into it after you remove some foam.
      07-13-2014, 11:53 PM   #22
sbottum622
Where can I actually buy the part though? Not sure I wanna go to dealer...
