02-23-2011, 12:34 PM | #1 |
Rep 14
3.0Si steptronic problem
Hi all, i've tried all over for answers and got nowhere so far
I've had my 3.0si auto roadster for about 3/4 week now and i've got a question regarding steptronic/stick sports mode etc obviously i've been havin a play around over the past few weeks and i dunno if it's normal or not but if i'm travelling on a motorway i can only use the paddles or stick to shift if the revs are 2100 in 6th gear (around 65mph) which is when it lets me go manual on the paddles or stick. If i'm on country roads i want to use paddles etc but unless i really give it the beans i get nothing from the paddles or stick regardless of sports button pressed or not. I can certainly feel the difference when the button is pressed but i just don't get the paddles or stick at all. I can use paddles sometimes until i come to a bend and start slowing then it switches back to full auto and won't allow me to use paddles or stick again. am i missing somethin as all the threads i've read seem that everyone else can use paddles wherever and whenever they like regardless of speed Thanks Steve |
02-23-2011, 12:46 PM | #2 |
Rep 4,057
If I have the gear shift in "D" and use the paddles, my car will let me use the paddles to select gears manually. But after a minute or so, the car will pop back into regular auto, unless I'm continually using the paddles.
Placing the shift in D and sliding to the left puts it in full manual mode. No automatic shifting at all, I think. I haven't noticed a case where I've asked the car to shift manually and it has refued to do that.
Huz-Z
02-23-2011, 12:53 PM | #3 |
Rep 14
it refuses to change under 65mph regardless of weather i have the stick pushed left or not, stick wont work nor will paddles, but take it over 65mph and it all works a treat
02-23-2011, 01:39 PM | #4 |
Gone but not forgotten
Rep 148
I have a 335 with step and if that is the case, then you have a problem. I can shift mine at any speed at any time, as long as it is within the parameters. In other words I can't downshift into first at 60 mph but I assure you I can use the step virtually anytime. Sounds like you are in for a trip to the dealer.
2015 Audi SQ5
RECENT PAST 2013 Porsche Boxster S 2009 335i/Coupe/Dinan S3 2006 BMW Z4 3.0si |
02-23-2011, 01:42 PM | #5 | |
Rep 14
yeah i was certain it should work anytime otherwise i really dont see the point in havin it as it only works on motorways lks like i'll be takin it back to whee i bought it |
02-23-2011, 02:13 PM | #6 |
Rep 4,057
Does the transmission shift properly otherwise, in D mode?
There are some very knowledgeable folks here. If you don't have to hurry to the dealer, why not hang on a day or two to see if anyone can shed more light on what may be causing this.
Huz-Z
02-23-2011, 02:17 PM | #7 | |
Rep 14
shifts no problem at all in auto, sport mode works no problem and it works no problem in all modes after 65mph the only issue is i cant use manual below 65mph |
02-23-2011, 02:55 PM | #8 |
Rep 4,057
I'm hoping that this is something cheap and easily fixed, like a fuse or something similar. Let's see if others here can offer assistance.
Huz-Z
02-23-2011, 02:57 PM | #9 |
Rep 14
02-23-2011, 03:17 PM | #10 |
Rep 4,057
Let me ask my local service advisor!
Huz-Z
02-23-2011, 03:29 PM | #12 |
Rep 4,057
It may be tomorrow before I get an answer. Is your car under warranty, by the way?
Huz-Z
02-23-2011, 03:31 PM | #13 |
Rep 14
02-23-2011, 03:36 PM | #14 |
Rep 4,057
Sounds good. I'll be back with a post as soon as I hear back from my service advisor, hopefully tomorrow!
Huz-Z
02-23-2011, 03:39 PM | #15 |
Rep 14
02-23-2011, 04:06 PM | #16 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
Transmission paddles not working
I really can't add to anything Huz has said.
If you pull the shifter to the left it should go into "MD" on the dash or "manual drive". This should allow you to shift up or down at any time (within the rpm parameters which the car uses to protect itself.) It is, in the MD mode, pretty much up to you when to shift, etc. Sounds like you have a problem. Hope its just a software issue. Reply to the thread when you get a definitive answer. I'll probably have the same problem later on down the road. |
02-23-2011, 06:41 PM | #17 |
Rep 822
My 06 si will change gears no matter how fast or slow I go. As long as it is within the rev limiter.If I touch the paddles it will change at least 1 gear. Some people did not like the paddle shifters or the way they were set up. I have seen where people reversed the wires so that the leaver above thew spoke of the steering wheel would up shift and the other side of the leaver behind the wheel would downshift ( operated with the fingers ) If you can get my drift here. You might want to try both and see if perhaps this has been done to yours. If the car is in high gear and you tell it to go higher it will do nothing.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
02-23-2011, 06:49 PM | #18 | |
Rep 4,057
On my car, whether you use the left or right paddle, moving the paddle towards the dash is a down shift - moving it towards the driver is an upshift. Nhopkins - I think the risk of you having this problem in future is low. In an earlier chat this week, my service advisor commented that the automatic transmission in the 2006 - 2008 Z4's are really quite reliable units.
Huz-Z
02-23-2011, 08:33 PM | #19 |
Rep 822
I'm just pointing out that the paddle shifters could have been modified and to try the other direction and/or the other shifter to see if there is a difference.
02-24-2011, 01:23 AM | #20 |
Rep 14
my paddle shifters are identical both sides, push away to down shift and towards you for up shift. The gears work absolutely fine over 65mph on both the shifters and the stick. They just cut out altogether under 65mph so the stick and paddles do nothin at all
02-24-2011, 06:54 AM | #21 |
Rep 4,057
I just heard back from my local service advisor and his advice is to take the car to a good BMW dealership to have this addressed. It may be a simple fix, but its very difficult to diagnose remotely. I am encouraged by the fact that the car works properly in Drive and Sport modes.
If you did not get the car from a BMW dealer, I would not let the vendor muck about with your transmision - that could make things much worse. Insist that he cover the cost of having the best local BMW dealership address this. As an alternative, you could seek out the guidance of Z4 guru Ron Stygar. I think he posts and monitors this board frequently: http://www.bimmerfest.com/forums/forumdisplay.php?f=7 Cheers!
Huz-Z
02-24-2011, 10:50 AM | #22 |
Rep 483
Huy-Z what year is your 3.0si? I think you have a bad fan and/or fan fuse which sets the tranny to "limp" mode which means you don't get to work paddles or stick. I had the same problem.
http://www.zpost.com/forums/showthre...hlight=ignores |
