      11-13-2012, 05:45 PM   #1
turboboosted
Drives: E90 | E92 | F10
LED Courtesy Lights
deleted
      11-14-2012, 01:16 AM   #2
midn12ght
gearhead goddess
midn12ght's Avatar
Drives: '13 sdrive35is
wait - so are these under the door, or for the floor - or both? i don't believe i have any in my door.
Originally Posted by Roffle Waffle:
I think a sack of fluid is pressing on the part of my brain responsible for common sense and fiscal responsibility
      11-14-2012, 08:54 AM   #3
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
We dont have those on the Zs. My 335 actually had an LED light under the door handle (where the key hole is incased) standard.
      11-14-2012, 04:01 PM   #4
turboboosted
It's for both!
      11-14-2012, 11:38 PM   #5
midn12ght
gearhead goddess
midn12ght's Avatar
Originally Posted by turboboosted View Post
It's for both!
ah, so they come with a connector cable like the license plate led's did? eyeing these...
      11-15-2012, 08:28 PM   #6
turboboosted
it should fit right on.
      11-16-2012, 07:09 AM   #7
JonM
Drives: E90 M3 Sedan
E85/E86 do not have lights in that location in stock form. There is no OEM wire harness in the door to connect those to. You would have to cut door panel material like Ron did. Or cut steel. You should probably understand your market a little better before you post.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      11-16-2012, 03:47 PM   #8
turboboosted
thanks for the head up. my bad. thread deleted.
