06-12-2015, 08:10 AM | #1 |
Rep 51
Hi,
Got some rubbing, how do I solve this the easy way? Raise the car even more? Larger spacer? EC-7 18x9.5 et35 fronts Toyo r888 255/35/18 KW clubsport H&R 5mm spacer |
06-12-2015, 10:31 AM | #2 |
Rep 407
I had the same issue with my KW V3's and ARC-8's 18x9" et42. Installed 12mm spacers with it and this was the result. Turns out it comes super low out of the box so it just didn't clear it. I raised it a little and it cleared just fine, no issue ever since. Don't worry about it, the car can still sit pretty low once you adjust it. Some camber would also help.
06-15-2015, 02:20 PM | #5 |
Rep 5,328
thats no where near enough clearance OP... you need to space the wheels out 5mm and use hub extenders or change to a less aggressive front wheel setup, the clubsport damper unit uses a helper spring so the perch sits right in line with the tyre, this reduces clearances, so when you push the envelope on what your running, what your seeing happens, but you need a minimum of 3-4mm clearance as the tyre deflects ALOT more than you'd think, you will damage your tyre and more expensively the damper perch if you run like this.
06-15-2015, 02:40 PM | #7 |
Rep 5,328
pics of car !!!!!!
06-15-2015, 09:41 PM | #8 |
Rep 12,565
12mm spacer should do the trick
06-17-2015, 01:35 PM | #9 |
Bimmer Noob
30
Rep 566
What front camber are you running? I use a 5mm spacer and run -3.2 camber in the front and no rubbing issues. Running a 18x9.5 et35 square setup with a 5mm spacer in front and 12mm spacer in rear.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
