      04-09-2015, 03:27 PM   #1
horsepit
horsepit's Avatar
Drives: 2014 BMW 550i
Can I run '14 550i wheels on my '06 Z4?
This may have been discussed but I can't find it. Can I run my 2014 BMW 550i wheels on the 2006 Z4? They are 19x8.5 ET33 and 19x9 ET44. Tires are 245/40 and 275/35. I guessing too big. I put M5 wheels on the 550 so I've got them sitting around and figure they would look a lot better than the little 17" on it now.
2014 F10 550i Space Gray| Avant Garde M355 20x9 ET35 + 20x10.5 ET38
| Michelin PSS 255/35 + 295/30 |
      04-13-2015, 07:24 PM   #2
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
You shouldn't have any issue running those specs
We typically recommend (F) 8.5 ET35 (R) 9.5 ET45 (no rubbing issues/ no modification). We do, however, usually run 245/35/19 | 275/30/19.
VMR V710 Example :
      04-14-2015, 11:01 AM   #3
horsepit
horsepit's Avatar
I'm guessing I was given the wrong spec's because I put on the fronts and the rim stuck out of the fender. Even if I changed the tires the wheels wouldn't work. So your picture is (F) 8.5 ET35 (R) 9.5 ET45 with 245/35/19 | 275/30/19? Is it dropped or stock height? And no rubbing, that looks great
      04-25-2015, 01:05 PM   #4
GP20
Z4 and Z4M have different wheel offset tolerances. For the non-M, you really need +ET40 at the front. You cannot fit a 245/40/18 tire without rubbing.
      04-29-2015, 07:29 PM   #5
BGR
Drives: C7 GS 7MT; e90 M3 6MT
You actually might be able to get away with that with some camber. Could always try and see what happens. It would be the fender that rubbed, not the strut.
