      05-16-2019, 07:08 PM   #1
Kazansky
Drives: BMW X7
Remiving trim clips in the trunk
How one removes plastic clips in the trunk to get access to battery in 2006 Z4M R? What exact tool is required?
      05-16-2019, 07:40 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
The expanding rivets? They should have screws in them to make them expand. Just take the screws out.
Then put the "tray" up by turning the knobs and remove the fix-a-flat and air compressor from the top.
There's 3 nuts up there that come off, and the box should pop right out.
      05-18-2019, 05:24 AM   #3
Mike 1
Drives: 2006 Z4MR
The rivets are sort of a pain. I put a fork behind the flange and then remove with slight outward presure. It works for me? Should have put while unsrewing.
      05-21-2019, 08:38 PM   #4
Kazansky
Drives: BMW X7
Metal fork worked. Not plastic tools. Now how do I disconnect the red plastic attachment and remove the battery?
      05-22-2019, 10:15 PM   #5
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
8mm socket.. loosen the nut and wiggle/pull.
      05-24-2019, 08:44 AM   #6
RossBMWZseries
Make sure it’s the nut in the back to the right of the positive terminal that you’re trying to remove, or else battery won’t come out. Here’s a picture from the top view provided by KevinC
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      05-31-2019, 03:31 AM   #7
Kazansky
Drives: BMW X7
Thank you all! Picture helped a lot. The larger nut was actually 14mm.
