      12-02-2017, 03:39 PM   #23
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Originally Posted by apexhittinbull View Post
2)I bought the S54 Cam Alignment tool kit which comes with TDC crankshaft lock pin, And I read that these need to be cut to fit on our E85/6 cars due to lack of space? Is this true, shall I go to the machine shop to cut the pin 2/3 of way?
It does need to be shorter. Here is the actual part used on our cars.
https://www.ecstuning.com/b-genuine-...n/83300495528/
Check out this thread for how short it should be if you're cutting yours.
http://www.zpost.com/forums/showthread.php?t=1112938
Good links and pics here, as well. The M3 DIY has lots of photos and step by steps.
http://www.zpost.com/forums/showthread.php?t=1048461
Salty
      12-02-2017, 03:47 PM   #24
wdb
dances with roads
wdb's Avatar
4718
Salty you need to change your avatar to a butt sticking out from under the hood!
Great info. I'm planning on doing the VANOS thing over the 'quiet time' this winter. Thanks for pulling so much information together in one place.
SaltyNC369.50
      12-02-2017, 04:30 PM   #25
coh661
Drives: 2007 Z4M Coupe
2007 Z4 M COUPE  [8.00]
milamookie, Thank you so so much! I read the posts so many times but it lacked pictures and lost. Thank you Thank you!
Glad to help, just paying it forward. Here's a link to my parts list. Note you may not want all these parts depending on what your doing. I plan on doing the whole overhaul. I also ordered some extra quantities of bolts and gaskets just in case.
https://docs.google.com/spreadsheets...0l5-6XtNhUkJsI
      12-02-2017, 08:21 PM   #26
apexhittinbull
Drives: E85 M
Salty
Thanks much for the guide to the post,
I had it cut at the local muffler shop for $10.
SaltyNC369.50
coh661191.00
      12-03-2017, 05:55 PM   #27
SaltyNC
SaltyNC's Avatar
370
I was traumatized as a teenager when I dropped a valve cover bolt down into an engine while trying to change a valve cover gasket and swore off working on engines. 35 years later, I'm finally getting over it.
Salty
wdb4718.00
      12-04-2017, 06:26 PM   #28
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Salty
Sounds familiar...
The cam bearing cap nut went down the timing channel somehow:
But I eventually retrieved it:
This was before I decided to tear the whole thing apart.
      12-04-2017, 08:06 PM   #29
apexhittinbull
Drives: E85 M
Gotta love the magnet
Was it swimming in the oil pan?
Hope I don't have to fish for anything this week doing the Vanos.
      12-05-2017, 05:30 PM   #30
mattfwalters
Sure was.
Put several layers of shop towel or clean rags in the timing chain channel, and make sure there aren't any gaps. That nut sneaked between the timing chain and the inside of the front of the timing cover to rattle its way down to the front of the sump. Sigh.
