      12-06-2017, 09:31 AM   #1
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Question about tuning and battery disconnect
Waiting for ess n52 sc to come in sometime next week, my question is will the upcoming recall that will be issued effect the ess tune from them disconnecting the battery etc
      12-06-2017, 11:00 AM   #2
Steeler
Steeler's Avatar
2428
What is the recall for?
      12-06-2017, 11:17 AM   #3
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
PCV Heater may Short Circuit
An electrical short can cause the parts within the PCV valve to melt, increasing the risk of a fire, even when the vehicle is not in use.
      12-06-2017, 11:24 AM   #4
Steeler
Steeler's Avatar
2428
Your tune will be fine
I unhook my battery every winter.
Is ESS sending a flash tuner? If so you can always reflash.
      12-06-2017, 11:27 AM   #5
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Yea it comes with the kit I believe, only concern was them having battery unplugged for x amount of time and then drivability from dealership home if tune was effected
      12-06-2017, 11:28 AM   #6
Steeler
Steeler's Avatar
2428
Naah you be all good
Have fun
Get an LSD
WickedNy225.00
      12-06-2017, 05:20 PM   #7
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Thanks appreciated.... lsd is next on the list most likely next winter along with headers n bpc tune ,
      12-06-2017, 07:27 PM   #8
Steeler
Steeler's Avatar
2428
BPC ques que ce?
      12-06-2017, 07:35 PM   #9
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Originally Posted by dbarton62 View Post
BPC ques que ce?
From my understanding ess hasn't been properly able to tune the n52 s/c along with headers. After digging through other posts it seems that bimmer performance center (BPC) in nc has been the only ones to successfully tune the n52 with headers and s/c combined. So I'll use what ess gives me for now till next winter
      12-06-2017, 07:44 PM   #10
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
The DME programming goes into flash memory, same type as in any USB memory stick. It doesn't require any power to retain the programming, you'll be fine.
Top Down 365
WickedNy225.00
      12-06-2017, 09:50 PM   #11
2282
ESS kit, wow! Congrats man... make sure you get the n52 MILV & headers together!
      12-07-2017, 07:02 AM   #12
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Thanks bud, hopefully I'll have enough in my secret slush fund by then to incorporate them
