      09-09-2013, 01:47 AM   #1
TestShoot
I1, I won
TestShoot's Avatar
Drives: E71 M, E60 535i
Cubby/nav box light fix?
aka rear console...
anybody ever have a good fix for this thing? like everyone else, mine stopped working and at night a matte interior is not so great for reaching in and rooting around for my altoids
bump to add a photo of the toggle/switch and say after swapping bulbs, it still does not come on :/
+-============[tSc]==============-+
http://www.TestShoot.com
      09-16-2013, 02:32 AM   #2
TestShoot
I1, I won
TestShoot's Avatar
photo bump
      09-16-2013, 12:28 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Usually the problem is the plastic tab breaks off the bottom of the door and they won't shut off.
Does the switch click nice and smooth when you diddle the lever?
If I get a chance tonight I'll check the schematics, but I think you should have power on one side of the switch; both sides with it removed like that, which should be the closed position. And of course, power on one side of the bulb socket.
      09-16-2013, 12:49 PM   #4
TestShoot
I1, I won
TestShoot's Avatar
Tab is fine, the switch feels like it is clicking, I was doing this all as part of an LED upgrade. I am debating making my own switch and wiring the light in to the emergency buttons since those are useless.
      09-16-2013, 01:31 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Good idea. Those buttons are useless.
      09-16-2013, 02:03 PM   #6
TestShoot
I1, I won
TestShoot's Avatar
once you have aftermarket stereo gear, they don't do any good thinking of replacing that spot with the change pocket thingy
      09-18-2013, 04:56 PM   #7
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
DId you use a regular bulb
If you tried an LED bulb and had it reversed it wouldn't come on even with power to it.
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
