      04-17-2012, 12:06 PM   #1
mike519
mike519's Avatar
Drives: 2018 M240i
Add power outlet in storage compartment
Anyone done this before? I wold like to add a power outlet in the centre storage compartment so that I can plug in cameras, phones, etc and keep them concealed while they charge.
If it matters, I have an '08 Z4.
Thanks
      04-17-2012, 12:44 PM   #2
spr_bimmer
Drives: 2004 Z4 Roadster
should not be too difficult, i'm sure you can just piggy back off of the current lighter wires
      04-17-2012, 02:59 PM   #3
mike519
mike519's Avatar
Drives: 2018 M240i
I was wondering about pulling it off of the light in the storage compartment. I think that should work but was wondering if any other thoughts.
Thanks
      11-18-2013, 02:34 AM   #4
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Bump.
Did you ever try this?
I'm considering it also... suppose the safe way is to run a wire from the cigarette lighter.
      11-19-2013, 10:19 AM   #5
3002 tii
3002 tii's Avatar
2280
Ron Stygar once did this, I recall seeing a write-up.
Follow for latest mods
      11-19-2013, 03:54 PM   #6
Tommy_hf
Netherlands
70
Drives: F36 CQ M, Z4 E85 3.0iS MSL SC
It's probably just as easy just to use some fuse taps for this job
      11-19-2013, 05:15 PM   #7
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Found it. I keep forgetting the battery is in the trunk. Make this easier vs going to the fusebox/or existing cigar lighter.
http://www.bimmerfest.com/forums/showthread.php?t=25528
      11-24-2013, 04:24 PM   #8
mike519
mike519's Avatar
Drives: 2018 M240i
Originally Posted by jmilt13 View Post
Bump.
Yup, did it just fine. Ran the power right from the battery with an inline fuse. Worked great!
