      11-03-2013, 01:18 PM   #23
Beedub
to learn alittle more about vanos timing, take a read and ask some questions here... stickmon is your guy, PM him
http://www.zpost.com/forums/showthread.php?t=908450
      11-03-2013, 07:28 PM   #24
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Originally Posted by dbarton62 View Post
No specific ideas other than double check ALL connections you touched or went near during the VANOS install.
Are you sure all the coil packs are seated properly?
So many things could have become dislodged working around under the bonnet, retrace the steps you took doing the work and eliminate those things as the problem.
Will do. Thanks!
