      03-17-2016, 09:57 PM   #1
DeutschRennfahrer
DeutschRennfahrer's Avatar
39
Drives: 2006 Z4 3.0i - Saphire Black
Fresh set of VMRs arrived today - WITH PICS
After waiting over a month for VMR to finish powder coating a set of v721s, they finally arrived today at long last. I will have some mounted pics posted here soon. Super stoked with how these turned out!
      03-18-2016, 06:32 AM   #2
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Those look fantastic, great choice what's the hammer for? Haha
      03-18-2016, 08:51 AM   #3
Twixboy
Drives: '04 Z4 3.0i 6spd
^ I was literally about the post the same question.
Those wheels look great. Too flashy for me to put on my black car personally, but I do like them a lot.
      03-18-2016, 10:06 AM   #4
DeutschRennfahrer
39
Haha I had some difficulty removing the stock wheels and thought I'd try some prying. Never seen wheels stick so tightly to the rotor after the lugs have all been removed. Obviously I would use a different tool when removing my new VMRs.
      03-18-2016, 10:59 AM   #5
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Wanna see it complete!!!
      03-20-2016, 02:00 PM   #6
DeutschRennfahrer
39
More pics after install:
      03-20-2016, 05:58 PM   #7
No_Dominion
No_Dominion's Avatar
117
Drives: 2007 Z4M Coupe
Nice! The color is subtle and works really well with the black.
Remote Start /// LEDs /// 20% Tint /// SGT Headers /// Gloss Black Roof /// Aero Sides
DKF Resonated S1 /// Mstache V2 /// Rear Diffuser /// CF Mirror Covers /// Eventuri Intake
MRR GF7 Wheels /// Evolve Tune /// CF Spoiler /// Michelin PSS
      03-20-2016, 08:28 PM   #8
torchmedia
Drives: White Z4MC
Originally Posted by DeutschRennfahrer View Post
DAT ASS... nice!
      03-21-2016, 08:57 AM   #9
Twixboy
LOL after removing all the lugs I usually give the tire a good kick to separate it (with a wheel pin removal tool in place of course). Once my dealer brushed some antiseize on the rotor hat of one wheel they removed. 4 months later when I had to take the wheels off, that one wheel came off with ease while the other 3 required a good kick to get them loosened.
BTW, why does your front end look lowered, but the rear looks like stock height? Wheels looks great otherwise! They don't stand out as much as I thought they would.
      03-21-2016, 11:15 AM   #10
3GFX
3GFX's Avatar
Love the style and colour on the car!!!!!!!!
What are your specs?
You need a drop next
      03-21-2016, 12:36 PM   #11
DaveJB
DaveJB's Avatar
46
Drives: 2007 Z4 M Coupe
May I ask what size tires and wheels you have? Those look like they're stretched pretty thin, IMO.
      03-21-2016, 02:19 PM   #12
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Those turned out beautifully! I love it! Don't forget to post in the Show Off Your VMR Wheels thread!
      03-21-2016, 10:35 PM   #13
DeutschRennfahrer
39
Thanks guys! I hear what you're saying about the stance difference between the front and the rear. There seems to be a ton of extra space in the back, but up front the stance is near perfect. VMR recommended a size 30 sidewall for the rear, and a 35 up front, which is likely the reason for the difference. I could easily fit a 35 in the rear and it would look a lot better than the 30 IMO.
      03-21-2016, 10:41 PM   #14
DeutschRennfahrer
39
235/35/19 in the front, 255/30/19 in the rear. I think I will go with bigger tires all around next time.
      03-22-2016, 03:07 PM   #15
jafxdwg
Drives: 08 3.0si Artic White with Red
Looks Great.
What size rims did you choose.
Width and offset would be a huge help for me.
Cheers
      03-22-2016, 03:51 PM   #16
DeutschRennfahrer
39
19x8.5" in front, 19x9.5" in back. I believe the offsets are ET35 and ET45; it's perfect for the car.
      03-22-2016, 10:55 PM   #17
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
With 235/35/19 in the front, you should of went with 265/30/19 in the rear to be more closer in rolling circumference to the front. 255/30/19 is slightly smaller in rolling circumference compared to the 235/35/19 front. If it doesn't rub, I would do 245/35/19F and 275/30/19R to get rid of that stretched tire fitment. 245/275 are perfect for an 8.5/9.5 wide wheels.
      03-22-2016, 11:03 PM   #18
DeutschRennfahrer
39
Why would you stick with a 30 sidewall in the rear? Why not go with 35 like the front? There is plenty of room and I think it would look better.
      03-23-2016, 12:40 AM   #19
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
30% of 265mm is approximately the same sidewall height as 35% of 235mm. 35% of 265mm or 255mm would make the rear sidewall taller than the front sidewall - although, this would fill in the wheel well a bit more, but it would also increase your rake (rear end being even taller). It's also best to keep the overall rolling circumference as equal as possible (same sidewall heights) front and back to keep all the electronic nannies happy.
      03-23-2016, 11:14 AM   #20
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
A tire's sidewall thickness is actually determined by combining the sidewall profile with the width (as measured in millimeters). Many don't know this, but the way tire sidewall thickness is calculated such that the profile number (in this case, 30) is treated as a percentage of the width (in this case, 255) to get the actual sidewall thickness:
255/30/19
255mm (width) * .30 (profile) = 76.5mm thick sidewall.
From there you can calculate the total outer diameter by multiplying the sidewall thickness *2 and adding in whatever wheel diameter (in millimeters) you're using. There are 25.4mm in one inch, so you multiply the wheel diam by 25.4 to convert to mm:
2(235*35) + 19*25.4 = 647.1mm outer diam (or 25.48")
2(255*30) + 19*25.4 = 635.6mm outer diam (or 25.02") - 1.78% difference from fronts
compared to
2(255*35) + 19*25.4 = 661.1mm outer diam (or 26.03") - 2.16% difference from fronts
For what it's worth, I'm guessing they made the recommendations to ensure a rub-free fit. The outer diams are only 1.81% different which is well within the golden rule (F + R should have less than 3% difference in OD). Those rear tires are recommended for wheels ranging from 8.5" to 10" so you should have no issues. Looks good to me but preferences differ.
Oh, and if anyone is too lazy to do the math there are a few nifty calculators out there like this -> www.1010tires.com/Tools/Tire-Size-Calculator Many use the calculators but I think it's good to understand why/how things change rather than just knowing the answers, hence the brief explanation above
Onto the pics! Are you lowered? If not, plan on it? These things look bitchin', I think the color accentuates the concave on the 9.5" too. Looks way deeper than my 18x10 VMR's, albeit they're a different model. With a drop and OEM rear spoiler I think you would take things to another level, would love to see that combo!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      03-23-2016, 11:23 AM   #21
DeutschRennfahrer
39
Thanks Tiltmode, this is all news to me so thanks for the insight!
I'm still on a stock suspension but this will be my next upgrade. I'd like some H&R coilovers, but that will probably have to wait a while. Any recommendations?
      03-26-2016, 06:04 PM   #22
DeutschRennfahrer
39
New pics posted
