03-06-2016, 11:15 PM | #1 |
Rep 341
Bolt torque setting help
Cleaned up the wheels and painted the calipers. What is the wheel bolt torque setting? I couldn't find it in the manual and did a search on this forum but also couldn't find it, or missed it.
I have OEM stock wheels on my 2007 3.0i 225 45 R17 I'm thinking 96# ? They are the 17mm head bolts Thanks, Last edited by doane2u; 03-06-2016 at 11:24 PM.. |
03-06-2016, 11:21 PM | #2 |
636
Rep 3,124
Pretty sure it's 88, but wait for some other bids before taking my word on it.
I always go 85 on all my cars. Never had a wheel fall off. Never warped a rotor.
03-07-2016, 12:16 AM | #3 | |
701
http://www.zpost.com/forums/showthread.php?t=122759 |
03-07-2016, 02:54 AM | #4 |
Rep 11,667
85 dry, no lube!
03-07-2016, 06:40 AM | #5 |
Rep 12,565
85-90 is fine but be sure to retorque after 100 miles or so
03-07-2016, 07:33 AM | #6 |
10770
Rep 4,890
BMW TIS states that you do use a thin coat of engine oil on both the threads and the taper when reinstalling the bolts.
ONLY if you use new bolts you dont use lube. This is probably due to corrosion prevention and seizing of the bolts. (new bolts have an undamaged passified zinc coating that gets damaged once used). Personally I always use a very thin coat of copper grease on the threads, applied with a brush. (I don't reapply it every time when I install the wheels) The correct torque spec is 120Nm (+/-10Nm), so 88,5ftlb (+/-7) to be precise. Obviously never use impact wrenches
03-07-2016, 10:05 AM | #7 |
Rep 341
Thanks everyone for your quick input, really appreciate it. I always hand torque and I use a very light copper anti-seiz from a stick on the threads.
03-07-2016, 01:17 PM | #8 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Man, I learn something new every day here. Is that copper grease available at local auto parts stores, or is that something that probably needs to be ordered?
Salty
03-07-2016, 03:22 PM | #9 |
10770
Rep 4,890
Yes you can buy copper grease at any autostore. Either in stick or tube or jar....
You can also buy ceramic grease which more or less funtions the same, but I prefer copper grease for the wheels (I think over time it sticks better and leaves a better thin film and has better anti galling properties, but I use both extensively). Both are anti seize products. |
03-07-2016, 05:39 PM | #10 |
Rep 341
I've been using mine for 20 years on many cars I've owned and never had trouble with lug nuts seizing, etc. Mine is sort of a lip stick looking stick with a cap on it.
03-07-2016, 11:34 PM | #11 |
636
Rep 3,124
Yea, I never heard of copper grease until I read about it in a few threads here.
Gonna get me some. I've always used WD-40 on pretty much any nut and bolt, but then switched to Liquid Wrench Super Oil.
03-08-2016, 06:52 AM | #12 |
10770
Rep 4,890
WD-40 does everything a little bit and none of those particulary good.
