03-10-2014, 12:21 PM | #1 |
Rep 598
VAC710 supercharger kit
710 crank hp. I didn't know this was available: http://store.vacmotorsports.com/vf-e...z4m-p2798.aspx
"VAC710 Supercharger & Engine System, Collaboration with VAC - Aftercooled high boost w/ built motor A.K.A. highest HP S/C kit available! Setup for high boost, V3-SCI trim supercharger along with VF's air/water cooled cartridge (aftercooler) inside their cast intake manifold. OEM spring tensioner upgrade, complete high flow fuel system and dual-pumps, MAF-less conversion with custom ECU Software to accommodate this. (header is required)." |
03-11-2014, 04:29 PM | #4 | |
Rep 2,176
03-11-2014, 11:55 PM | #5 |
Rep 598
Since it's going to be a built motor, a lot of variables will affect the pricing. I think this kit is custom config and pricing for each customer. Are there reasons to think VF/VAC can't get the kit to run properly?
03-12-2014, 04:08 AM | #7 |
701
Reasons? Yep. Some folks have ongoing software issues. Others couldn't get them to bother to ship product after it had been purchased. I know about two of those cases personally. So call me an educated skeptic.
04-09-2014, 04:15 PM | #8 |
Rep 598
This is supposed to be the 710 kit on a z3m:
http://www.vacmotorsports.com/projec...hp?recordID=28 |
04-09-2014, 06:49 PM | #9 |
Rep 347
Drives: 2006 BMW M COUPE
9 lbs boost is too much and fuel pump pressure could be a problem - it is bound to be not very reliable and prone to "never " working the way it should - 500HP - buy a new M-5 or6
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
04-09-2014, 10:48 PM | #10 |
enthusiast
48
Rep 1,695
I am always hearing about tuning the z4m. If you really want to mod it, get a stand alone for 3-5000 and tune it for anything just how you want.
04-10-2014, 08:17 AM | #12 |
Rep 2,665
I am confused, I read about aftermarket companies not being able to tune the car so instead I should get a custom tune and do it myself. If they can't do it how will I? If it's not that difficult why can't they do it? I do understand the custom tune may get the most possible out of my specific car but at a slightly lower level and much lower expense and hassle why can't they do a "standard" system? How could the custom tune be "much cheaper" than a full standalone?
04-10-2014, 08:47 AM | #13 | |
Rep 2,176
George |
04-10-2014, 10:19 AM | #14 | |
///M-fanatic
192
Rep 3,885
I myself went with a remote tune through Frank Smith, and he's helped my car tremendously. We're still going through the final phases of datalogging and minute tweaking of the part-throttle driveability, but the car has come a long way thanks to Frank. The original supercharger tune provided with VF Engineering's kits were atrocious My car ran like absolute crap. If I hadn't gotten the kit at a really good deal, I wouldn't have bothered putting up with their bullshit. Their customer service is horrid |
04-10-2014, 11:30 AM | #15 | |
Rep 2,697
My car is at a much much lower tune than others but the limited interaction I have had with VF has been satisfactory.
The original tune for my application was too rich and kept tripping limp mode. Their tech remapped my ECU and remotely installed it for me. It seems to be working good so far since. Quote:
04-10-2014, 12:53 PM | #16 | ||
Rep 2,782
When I initially sent my ECU to them, the turnaround was acceptable. Responses from technical support have been mixed. I have had a few outstanding responses, and other times I've been ignored releatedly.
04-10-2014, 02:08 PM | #17 | |
Rep 2,697
I have yet to run mine under load, I ran it at high revs for quite a long time after the remap was installed with no limp mode where before it would go into limp mode under the same conditions Will know the whole story once it goes on the road in a few weeks.
04-11-2014, 04:39 PM | #18 |
Rep 2,782
Dave,
It stalls in the sense that the car will no longer accelerate, rpm's bounce off idle, and it ceases to accept throttle input. It's accompanied by a dash full of lights, including an EML. I'll see if I can dig up a video.
04-11-2014, 04:44 PM | #19 |
Rep 2,697
Exactly the same symptoms for me Josh.
Just need to get the exhaust back from coating and I can report if the retune by VF has worked.
04-11-2014, 07:04 PM | #20 | |
enthusiast
48
Rep 1,695
AEM makes a unit. Andrew Lang, as well as many others, can wire it up for you in a day ($1000). http://store.langracing.com/aem-infi...gement-system/ |
04-11-2014, 09:38 PM | #21 | ||
Rep 2,176
George |
