      03-05-2014, 10:27 AM   #1
bjbstewart
bjbstewart's Avatar
Drives: 2007 BMW Z4MC
NorCal Mechanic for Rod Bearing R&R
I just got in on a GB for coated bearings. Only have 37k miles on the car, but feel like this is something that will need to be done sooner than later. Would like a reference or two for shops in the area that actually have experience doing this on an S54. Pretty sure my "guy" has no idea...
so, any good shops in NorCal (i'm in San Jose, but will certainly travel 60+ miles for an experienced and recommended installer).
TIA!
[SIGPIC][/SIGPIC]
      03-05-2014, 10:50 AM   #2
wss4
Drives: 2008 Z4 M Coupe
Performance Technic in Pleasanton has been great with my car.
      03-05-2014, 11:11 AM   #3
bjbstewart
bjbstewart's Avatar
Thanks! did they do the Rod Bearing install for you?
[SIGPIC][/SIGPIC]
      03-05-2014, 02:07 PM   #4
wss4
I had them refresh an engine to drop into my car - rod bearings/bolts, oil pump upgrade, valve adjustment, VANOS cam bolts, etc. They work on a lot of S54's and know the engine very well.
      03-05-2014, 02:27 PM   #5
The_Ring_Monster
The_Ring_Monster's Avatar
Drives: '07 Z4M
Just sent you a PM, hope this helps!
Cheers
      03-06-2014, 12:46 AM   #6
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
+100 on P-Tech. Tell them guys from Zpost recommended you. They will take care of you. You might as well have them weight your car while you are there.
