      05-26-2018, 10:44 AM   #1
Flipckyz4m
Drives: 08 z4m
thumping noise on slow/tight turns
Anyone experience this before with their m coupe? Only getting these thumping sounds turning 180 degrees in a parking lot setting. Car was aligned recently so that shouldn't be an issue.
      05-26-2018, 11:20 AM   #2
Huz-Z
Huz-Z's Avatar
I had a similar problem years ago on my Z4 3.0si. While my car has a different steering rack than your car, I fixed it by tightening the bolts on the strut braces in the engine compartment. It’s worth a try on your M - just be careful not to over tighten. Someone here may have the proper torque for this.
      05-26-2018, 09:41 PM   #3
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Try backing in a circle clockwise and counter clockwise and see if you hear the thumping. If it's an issue with a control arm bushing this will accentuate the thumping significantly.
Top Down 365
      05-27-2018, 02:40 AM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
Coming from the front or the back?
The LSD will grump and groan a bit, it's just doing what they do.
      05-30-2018, 01:20 AM   #5
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
if its like a grinding kind of sound coming from the rear on tight left/right turns then its most likely the LS diff... I use to get grinding/binding sounds when taking tight turns just after starting up the car... If i drove a few miles for everything to warm up and then tried doing any tight turns, the sound would be faint or gone... i guess this was because by then the oil would have properly shot up everywhere and lubricated the diff after a few miles... This is how you can test if its the diff... Start the car up, drive it about half a mile and then drive around in tight circles, you should be able hear the sound... after that drive the car for a few miles; Highway is preferred to get everything all nice and lubricated then stop somewhere and try to do tight turns to see if you hear the sound... if the sound is no longer present after the highway run, then its definitely your diff...
I ended up rebuilding my diff with new timkin Bearings, seals and BMW oil with FM booster and now there's no more funny sounds..
I've experenced this on 3 M Cars : E86 M, E85 M and my brothers E46 M3 and i rebuilt all 3 diffs with new seals and bearings to resolve the issue.
Hope this helps, see my journal for more details..
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      05-30-2018, 09:25 AM   #6
3002 tii
3002 tii's Avatar
2282
What others said, if the sound is from the rear it’s most likely the diff. Uneven tires or alignment settings will probably make it worse. You can always throw in some friction modifier if it bothers you enough.
Follow for latest mods
      05-30-2018, 10:08 AM   #7
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Strut Braces
My strut brace bolts were loose and were causing a similar errant noise.
Racerbruce
      05-30-2018, 10:14 AM   #8
MinneapolisJeff
Drives: 2003 BMW Z4 3.0i
same; I torque'd one brace to 25 ft-lbs and my noise went away
the stable:
2003 BMW Z4 3.0i
2020 Mitsubishi Outlander SE
2021 Jeep Gladiator Rubicon
      05-30-2018, 11:18 AM   #9
Huz-Z
Huz-Z's Avatar
I'm really hoping I'm right - not because I have a need to be right - but because its the cheapest and easiest issue for the OP to fix.
Huz-Z
      05-30-2018, 12:41 PM   #10
Flipckyz4m
Drives: 08 z4m
Yes it's actually more of a grinding sound than thumping now that I recall. LSD argument makes a lot of sense although it sounded like it was coming from the front than back. But then again, i am sitting right on the rear axle so maybe it was coming from the rear. I'll try making some tight turns after car is fully warmed up. Thanks for the replies.
      06-08-2018, 07:55 PM   #11
Big Mexican Women
Drives: 2011 528i
if it's coming from the front it is most likely ball joints
      06-08-2018, 10:35 PM   #12
Flipckyz4m
Drives: 08 z4m
Update: applied some differential lubrication and the noise is mostly gone on tight turns. Cheap fix
ZAR4MC93.00
