      09-26-2014, 10:44 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Need VT2-525 stats/feedback
Has anyone taken their VT2-525+ car to the drag strip? I'm interested in what kind of trap speeds you're seeing. Also what your dyno is showing.
I've been running a 2.87" pulley on my VT2-500, and was really dissapointed that the trap speed was only 110, compared to 117 on my stock pulley. I guess the belt slip is a lot worse than I thought.
      09-27-2014, 05:55 AM   #2
Beedub
are you seeing lots of belt dust?
swapping to the smaller pull on the s/c and not changing out some of the others i think i giving you lots of belt slip, best way is to get a dyno surely???
are you carless too? you'd expect some decent HP but clearly something is a miss.
      09-27-2014, 10:06 AM   #3
ZStig
279
Yeah lots of belt dust. I'm on my second belt. The pulley offset is custom to match the research I did online, but its off by 1mm and eating belts. I'm going back to stock pulley.
Yes catless
Haven't dynoed yet but the trap speed tells me a lot about the power output. Its gotta be under 400rwhp peak
      09-28-2014, 11:27 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Are you able to use a spacer?
      09-30-2014, 06:01 PM   #5
ZStig
279
Yeah I considered it, but it would probably slip anyway, and the belt dug some extra grooves into the custom pulley. So not sure if its usable.
Might try though. Can't get it off without an air gun though
      10-04-2014, 11:41 PM   #6
seank
enthusiast
seank's Avatar
48
No sorry. No data, other than my 0-60 was faster when i had a leak than it is without leak. Wheel spin.
      10-05-2014, 01:30 PM   #7
ZStig
279
8psi and 430rwhp is the expectation, right?
      10-05-2014, 08:54 PM   #8
seank
enthusiast
seank's Avatar
48
I get around 9.4 psi when its cold outside and around 9 when it is cold. George would probably know the answer to rwhp since he has been on the dyno so many times.
      10-05-2014, 10:14 PM   #9
ZStig
279
are these the injectors they use?
http://www.amazon.com/dp/B00B1HWTZU/...d=IOVS9G0VPZ11
      10-08-2014, 12:01 PM   #10
gmd2003
gmd2003's Avatar
352
420-430whp depending on temp on a realistic dyno .
      10-09-2014, 02:04 PM   #11
ZStig
279
Gotcha. My shop will get me a 1psi bigger crank pulley since only the bigger 3.22inch blower pulley is available. And i think a few people are on 3.125inch blower pulley but ess says it will slip. Aiming for above 430rwhp
