05-08-2018, 10:30 AM | #1 |
Rep 229
Goof Off
Question: Will Goof Off Pro Strength Super Glue Remover dissolve the clear coat from your wheels?
Answer: YES!!!! ARRRRRGGGGGHHHHH. Tried to remove leftover wheel weight adhesives and found out the hard way. I'm guessing that one of the other Goof Off products would have been a better choice. Pardon me while I search for paint color and wheel touch up procedures. |
05-08-2018, 03:32 PM | #2 |
636
Rep 3,124
I did the exact same thing.
Luckily, I had a feeling it might happen, so I chose a spot deep inside the barrel to try first. The only thing I've found so far that safely removes leftover wheel weight adhesive is fingernails.
05-08-2018, 05:35 PM | #3 |
Rep 12,565
I’ve used bug and tar remover on some of the worst adhesive residue and it came off pretty easy, didn’t see overly harsh neither
05-08-2018, 09:36 PM | #4 |
Rep 229
Thanks, guys. Is there an actual paint code/name for the paint on Z4 M wheels. I've seen some posts that indicate that its not the same as the non-M. My concern is that, if I give the wheel to a professional (Dent Wizard Wheel Repair in Phoenix), that they won't be able to match. Thanks, again!!
05-08-2018, 10:55 PM | #6 |
636
Rep 3,124
I'm used to using WD40 to lubricate stuff, but I'm just learning it's worth to clean stuff after using it successfully to clean year old ink off my whiteboard at work.
Used it again recently to clean some goo off my garage floor.
05-10-2018, 09:17 AM | #8 |
dances with roads
4732
Rep 4,096
WD-40, some elbow grease, and repeated applications has worked for me for adhesive removal. I've also used citrus-based "goof off" type products in the same fashion with similar results.
05-16-2018, 06:02 AM | #10 |
Rep 870
Drives: 2006 BMW Z4M Roadster
3M Adhesive Remover in the aerosol can works great, too, and it doesn't harm paint/clearcoat. I bought it to remove a clear bra, and have been using it for all sorts of adhesive removal jobs since then. Good stuff.
Salty
wdb4732.00 |
05-16-2018, 10:59 AM | #12 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
Wd40 on everything glue related.
