      12-21-2009, 10:27 PM   #1
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
oz superleggeras for 07 mzr roadster - will these fit??
oz ultraleggeras....z4m roadster fitment
i luv oz's...had an 18 in set on m s2000.
looking to purchase these (below) for the 07 z4m roadster....will these fit?
oem 18's:
front: et 42
rear: et 30
oz 18's:
front: et 40
rea: et 40
O.Z. Ultraleggera
Finish: Black Painted
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Rec. Tire Size:225/45-18
Weight: 18.6lbs.
Rear Fitment
18x9
Offset: 40mm
Backspacing: 6.57"
Bolt Pattern: 5-120
Rec. Tire Size:255/40-18
Weight: 20.8lbs.
      12-22-2009, 12:54 AM   #2
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
you will need 10mm spacers for the rear and it will still look sunken in w/those dimensions.
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      01-23-2010, 10:23 PM   #3
stubble88
Drives: 2013 e92 ZCP blue
why would this still look sunken in?
im going with the OZ
nice light weight wheel
I might even go with a 12mm spacer but need to check rubbing with 275's on the rear.
      01-23-2010, 11:43 PM   #4
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Ideal offset for rear wheels around 9-10" is +20/+25.
9" with +40 will be worse than stock. Stock is +32 i think.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      01-24-2010, 12:49 AM   #5
stubble88
stock is 30
Im thinking of using spacers on a 40 wheel (OZ) to get to 28.
I would like to here more about what people are running in the rears.
Im going to do a 18x9 OZ wheel with 40 offset then a 12mm spacer = (28), running a 275/35 wheel.
      01-24-2010, 01:12 AM   #6
VitaminT
Drives: 2006 M Roadster
I gathered a bunch of people's specs from their setups on M roadsters/coupes a while back and this is what I came up with. If I remember right the number in () is the difference in MM than stock. Note + is sticks out further.
One other things and it is just personal preference, but why if you are about to spend money on wheels would you buy something that requires spacers? Most wheel companies have a range of offsets to pick from. I also think that TireRack has the ability to build custom 3pc OZ wheels by mixing and matching hoops and faces.
Take the following as just guidance as some numbers might be wrong or fat fingered etc.
our original wheels are the following size
F 18 x 8 ET42
R 18 x 9 ET30
The original E46 M3 CSL wheels fit really tight with the following specs:
19x8.5 ET44 (+4)
19x9.5 ET27 (0)
E90/92 M3 Wheels
18x8.5 ET29 (+19)
18x9.5 ET23 (+13)
19x8.5 ET35 on 245/35 (+13)
19x9.5 ET22 on 275/30 (+14)
19x10 ET25 on 275/30 (+18)
18x8.5 ET35 on 245/40 (+13)
18x9.5 ET22 on 275/35 (+14)
19×8.5 ET34 on 245/35 (+14)
19×10 ET26 on 275/30 (+17)
19x8.5 ET30 on 245/35 (+18)
19x10.5ET25 on 275/30 (+25)
MCoupe with Blue Work Meisters
19X9.0 ET35 (+20)
19X10 ET17 (+26)
TireRack BBS LM Fitment
19x8.5 ET32 on 245/35 (+16)
      01-24-2010, 01:20 AM   #7
VitaminT
Also just something to note is that most 275 tires, while still approved for a 9" wheel, will hang past the rim a bit. You will probably find most people running that tire size on a 10" wheel.
      01-24-2010, 01:51 AM   #8
The__J__Factor
Australia
88
Drives: ///M Coupe
I run 275 on the stock rim and it looks perfect.
135i N54 manual
