12-28-2013, 08:08 PM | #1 |
Rep 392
Crank-but-no-start I need your help :)
Hello
I left my z sitting outside for 3 weeks in -10F while I was on vacation, Today I tried to start it and it cranked slowly at first but later at a pretty good pace and was not able to get it to go. I have taken the following initial step:
I went over this thread: No start and this one Ignition/start failure It seems to crank and go faster and faster until ultimately it chokes itself and dies. until it starts over again. obviously some of the things I tested like the fuses and the fuel and the battery can be further tested, also I don't know if there is any spark but there are no codes or cel. The car used to start perfect every time, also the coils where replaced 30k miles ago at the dealer. This is a 03 z4 Thanks a lot in advance
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune Last edited by rkstar9; 12-28-2013 at 08:51 PM.. |
12-28-2013, 11:01 PM | #2 |
636
Rep 3,124
Flooded?
Anybody know an easy way to cut the fuel flow? The last cars I had flood in sub-zero weather had throttle-body injection. The solution was to unplug the fuel injector and crank it until it dried out.
12-29-2013, 03:15 AM | #3 |
Rep 279
Probably.
Plugs are most likely fouled at this point. Maybe remove fuel pump relay see if it fires? I used to have to do this with my older BMW's along with letting some unmetered air in when seriously cold out.
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
12-29-2013, 08:14 AM | #4 |
Rep 104
Is it stick shift car?. If so have someone pull start you in second gear. That thing needs more cranking speed. I noticed your temp was 44 degrees, Mine cranks a lot faster than that at that temp. Battery or starter not right. I know it should still start but probably flooded like others have stated, that's where the pull start will blow out the excess fuel.
12-29-2013, 10:45 AM | #5 | |||
Rep 392
I pulled the dipstick out and did not see any signs of fuel mixed with oil so it's probably minimal. Quote:
I see 2 fuses for the pump, so do I just pull them out and crank it ? how will I know when the fuel is dissipated? Quote:
Additionally, the car has been throwing codes for the thermostat value below threshold, about 4 weeks ago I found the coolant was almost completely empty and the engine was overheating, but the low coolant light did not come on. I read on another forum where a faulty coolant temperature sensor can cause the engine to flood, but it wasn't explained why.
x5d e70 DUDMD stage 2 tune Last edited by rkstar9; 12-29-2013 at 11:01 AM.. |
12-29-2013, 02:09 PM | #6 |
Rep 104
I read on another forum where a faulty coolant temperature sensor can cause the engine to flood, but it wasn't explained why.[/QUOTE] Coolant temp sensor for fuel injection is like a choke. The colder the engine is the longer the injector stays open. If the engine is 160 degrees and the sensor thinks its 50 degrees, then you got hard starts or no starts possible. |
12-30-2013, 12:14 AM | #7 |
636
Rep 3,124
If it goes anything like the throttle-body injected Chevy's I've started, as soon as one or more plugs fire it'll ignite the fumes in the intake and sneeze.
Then it'll start firing more and more and eventually start, just on the fumes, and then run out of gas. Then you reconnect the fuel and it should start without too much problem.
01-01-2014, 01:24 PM | #8 |
Rep 392
It started with a jump from my e150
Battery appears to be fine as well, only left it sitting overnight yesterday but it seems fine. Thanks everyone. Update: the car failed to start one more time and even the dome light strugled to turn on. So I left the car sitting for about 2 weeks in the cold. One slightly warmer day decided to go jump start the car again with the e150. But just for shits and giggles tried starting it as it was without the jump. It started right up! even after the battery was completely dead and sat for 2 weeks! then immediately I took the car to autozone and battery tested just fine. I guess the morale of the story is these batteries are not made for -30f weather. and even after your battery is dead because of the cold, it can come back on it's on once temperature is restored.
x5d e70 DUDMD stage 2 tune Last edited by rkstar9; 02-10-2014 at 08:28 PM.. |
01-03-2014, 11:36 PM | #9 |
instagram 997turbotom
279
Rep 7,377
I'd be afraid of damaging something by cranking the car for so long. I only try to start it for about 4-5 seconds at a time.
I'm having a fast crank but no start issue fairly often, so I'm replacing the crank position sensor tomorrow as per my research
