      11-15-2008, 09:07 PM   #1
Black///Mamba
Black///Mamba's Avatar
52
Drives: a beast
Winter Wheel Setup
Hey guys,
For those of you that have to deal with winter and your Z's, what setup do you guys use?
i just picked up 4 18x8 OZ Superleggeras. Was planning on wrappign them in winter dunlop M3s and put 10 or 20 mm spacers in the rear
      11-16-2008, 11:00 AM   #2
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
304
Drives: '07 M Coupé & '16 435xi GCoupé
I've got my OEM M wheels wrapped in Dunlop WinterSport M3s.
      11-16-2008, 06:55 PM   #3
AtoB
AtoB's Avatar
Drives: Z4M
same. they worked well last winter
      11-16-2008, 07:19 PM   #4
Spartiati
Spartiati's Avatar
Drives: 2008 Z4 M Roadster
I have a set of cheap 17" wheels from tire rack that I purchased for my e46 M3 that I plan to use on my Z4MR. Believe they are 17x8F and 17x9R. Can't recall exact offsets but probably very similar to stock. Have Dunlop Winter Sport M3's on them and have been impressed with their performance in the snow.
      11-16-2008, 10:07 PM   #5
jgorman13
Drives: 2005 Z4 3.0i, 2008 C300 Sport
Using my stock wheels once my CSLs come in. Probably going to burn the stupid RFTs (hehe) and put blizzaks on them
      11-19-2008, 07:32 AM   #6
Black///Mamba
52
Drives: a beast
will i run into any problems by running 4 18x8's in the winter? i know i'll have to go a bit easy on them, but i should be alright...?
      11-19-2008, 10:06 AM   #7
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
As long as they fit on the car, you won't have issues in terms of driving.
You actually want narrower wheels in the winter. If you had 8.5's up front and 10's in the back, you'd be floating over the snow, rather then cutting through it.
      11-19-2008, 10:57 AM   #8
Black///Mamba
52
Drives: a beast
very true. i actually just found a great deal. found a stock oem m3 set with brand new pirelli snow tires locally. going to pick these up and sell the OZs. Damn winter~!
      11-19-2008, 12:34 PM   #9
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I scored a set of 17" 5 spoke wheels and almost new Blizzaks for $350 on craigslist!!!
      11-19-2008, 02:58 PM   #10
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
I've been running 225/45/17 Dunlop runflat M3 winter sports on 17" M3 replica rims for the last two winters. They work like a charm. The car still slides a bit on turns when there's a layer of snow on the ground (mostly because of RWD and 'cause the car is really light), but otherwise, I feel quite safe in my Zed.
I can't wait to put my 18" M6 replicas back on though. The difference is just huge in terms of looks. When I put the 17" winters on, they look tiny.
      11-19-2008, 11:52 PM   #11
Rick Hunter
304
Hey... I didn't know you had M6 reps. Kudos!
      11-22-2008, 10:51 AM   #12
saintex
Drives: Z4MC BSM E92 335xDrive BSM
Regretfully I followed the advice in the MC manual which recommends 225/40R18. I put these on a set of stock rims I bought separately on EBAY. Vredestein Wintrac, good tires but the profile is too low for winter and the speedometer error is brutal now.
I should have put 225/45r18 instead and ignored BMW advice.
      11-22-2008, 03:41 PM   #13
takedown8
takedown8's Avatar
I finally caved in after seeing the amazing pics of people's Zed's with the M6 reps (including yours!). The first week after getting them, I worried that they were a touch flashy....but after that, I realized that they just looked damn awesome!
saintex, with the amount of snow you get in Montreal and surrounding areas, I would highly recommend you ditch those tires and get yourself some Dunlop M3 Winter Sports. It's worth it safety-wise, and I don't mind driving non-RFTs in the summer, but I wouldn't want to get stranded in the dead of winter so I went with winter RFTs.
      11-22-2008, 04:04 PM   #14
saintex
This will be winter number two for the Z4MC. I've been running Vreds in the winter and summer versions for ten years and am quite satisfied and at any rate I don't think the M rims will hold a RFT, summer tires are not RFT and I have the stock tire repair compressor in the trunk. But thanks for your concern.
Search this Thread:
Advanced Search
