09-19-2013, 03:37 PM | #1 |
Rep 347
Drives: 2006 BMW M COUPE
Arc 8 wheels or 7's
IF I was to put APEX arc-8 wheels on that are
18 x 8.5 ofst 38 on the front 18 x 9.5 ofst 35 rear WOULD - these tire size fit the wheels and the car " Front 235/35 -18 or for that matter 245/35 - 18 rear 285/30 - 18 The combinations seem to be endless and I don't want spacers Apex arc e-7s front 18x8.5 35 rear 18 x 9-5 22 same tires thanks as always to the real experts
09-19-2013, 04:28 PM | #2 | |
Rep 1,663
Far from an expert, but here's what I'd recommend:
For 8.5/9.5 wheels I'd recommend 245/275. 285 will likely give you less grip and performance than 275. Here's a thread with some beautiful 255/275 on arc-8. http://www.zpost.com/forums/showthread.php?t=865009 I'd still recommend 245/275 just because it's about the largest you can fit with zero rubbing under any circumstance. And it's an ideal size for the rim width so you get the full contact patch. Finnegan in testing showed that having a smaller rim than the tire (even if the tire fits) gives you less performance than having the right rim width for the tire.
09-19-2013, 04:56 PM | #3 |
Rep 347
You are correct -- the arc 8 with 22mm rear offset in 9.5 is the wheel but is not the 285 / 35 only .5 inches wider than the 275 - how would you get less grip - the 285 / 30 are too much of a change in circumference
So wheels are 18 x 8.5 -35 - and 18 x 9.5 -22 and then Tires - 245x35 - 18 and 285 x 35 - 18 - Would they not fit OK ? Numbers drive me nuts
09-19-2013, 06:28 PM | #4 |
707
285 x 35 isn't going to fit without a lot of negative camber and probably some fender rolling. 245/275 is going to fit fairly easily front/rear, especially if you go with a rounded sidewall like the PSS. Square sidewalled tires, e.g. the Direzza II, will have better fitment in a 235/265 fitment on your choosen wheel size. A square shouldered 275 tire will need negative camber at the very least, and lots of it.
285 vs. 275 only gives a 4/10ths increase in section width, and you'd be stuffing it on to a wheel that has is the minimum width possible. Min width for a 285/35 tire is a 9.5". Really needs a 10" or wider wheel, otherwise you're not going to use all that fat tire you paid for--basically you'll be using the center of the tire. (As Beta said, I've tested this using a pyrometer.) 10" wheel with a 285/35 tire isn't going to work without some serious work. |
09-19-2013, 07:19 PM | #5 |
Rep 347
Thanks Finnegan - if you ever need any advice on a root canal let me know,
ARC - 8 Front 18x8.5 - et 38 Tire 245/35 -18 Rear 18x9.5 - et 22 Tire 275/35 -18 Sound right this time - I noticed that the offsets for the Arc-8s have changed over the last while 0
09-19-2013, 10:06 PM | #6 | |
Rep 1,663
245/40 275/35 245/35 would be -4.7% smaller than stock, which is way too small (anything over 3% is said to cause issues with the DSC). For reference: 245/40 -0.99% smaller than stock 275/35 -1.74% smaller than stock
09-20-2013, 06:59 AM | #7 | |
Rep 347
The 8-5" /18 ARC 8's have an offset of 38 but the ARC 7's have a 35 -- does it matter which one? I notice that it must be older stock but EAS has a set of them and the 8.5's are actually offset 45 which I think would keep them in more - which is preferable ?
09-20-2013, 12:44 PM | #8 | |
Rep 1,663
So you either want the Arc-8 et38 or the EC-7 et35. If you got the 45's you'd have to get a 5-10mm spacer.
09-20-2013, 01:41 PM | #9 |
Rep 347
You're the man !!
09-23-2013, 09:31 AM | #10 | |
Rep 501
09-23-2013, 01:19 PM | #11 |
Rep 1,663
Yes. And if you ever get coilovers (or lower the car) you'll push your camber out to somewhere around -2 approximately and it will be perfect as you'll get your scrub radius almost back to stock.
09-23-2013, 01:58 PM | #12 |
Two Wheels or Four?
95
Rep 655
I was on the fence about which of these two sets of wheels to get, and this weekend at the track there was a 1M with the Arc-8s and an E90 with the EC-7s. I think it's going to be Arc-8s for me!
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
09-23-2013, 02:55 PM | #13 |
Rep 347
I think I will as well - have to wait till my Boss (She who must be obeyed ) isn't handy
