      08-15-2010, 10:40 PM   #1
dekaliber
Drives: '07 Z4MC, '11 JCW, '18 Z06
Can an M owner measure the rivets in their front wheel well?
Looking for someone who has an M who knows 100% that they have never had any sort of front bumper work done to chime in here...
Could you measure the width of the 4 rivets on the inside of the front wheel well, fastening the wheel well lining to the front bumper?
(original photo by mister_roger, sorry for borrowing it)
I'd like to know if it's 15mm or 20mm.
The 20 mm ones are these blind rivets, which is what I found on my car. However, I think the previous owner had the original bumper resprayed, so I don't know if these were the same ones used from the factory. I was told by the parts person at my dealership that they should be these push-pin rivets, which are 15mm wide and match the ones shown in mister_roger's DIY. However, I'm not sure if the M's use the same ones.
I ordered the latter (the blind rivets are single-use), but they almost seem a little small for the holes and don't seem to secure as tightly as the blind rivets that were there before.
      08-15-2010, 11:49 PM   #2
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
All 20mm on mine, bumper never removed.
      08-16-2010, 10:34 AM   #3
Ron Stygar
Drives: 2006 Z4 M Coupe
Mine are 15mm.
      08-16-2010, 10:41 AM   #4
RBull
Drives: 2007 M Coupe
Mine are 20mm. Don't know if bumper had been removed or not.
      08-16-2010, 10:48 AM   #5
Ron Stygar
http://www.bimmerfest.com/forums/sho...8&postcount=48
      08-16-2010, 10:57 AM   #6
dekaliber
Thanks everyone for your input. Maybe I should just pay my local dealer a visit so I can see everything in person. I feel silly for paying so much attention to such a small part.
Originally Posted by Ron Stygar View Post
Ron, there appears to be a 2nd style of pop rivet without the beveled edge (middle one in the post you linked to). The PN is 51717002953.
I came across it while dismantling the underbody cover. There are two of these securing this metal tab underneath (#25 in the following diagram):
http://www.realoem.com/bmw/showparts...60&hg=51&fg=15
They are identical to the rivets that were holding my bumper to the wheel well lining, and measure 20mm across.
      08-16-2010, 12:34 PM   #7
Ron Stygar
They were pop rivets there?
OK.
What came with my car follows the parts data.
Rivet 296 for the wheel well to the bumper: Item 10 quantity eight.
http://www.realoem.com/bmw/showparts...41&fg=10&hl=16
Pop rivet 274 item 11 quantity two:
http://www.realoem.com/bmw/showparts...51&fg=75&hl=26
      08-16-2010, 12:54 PM   #8
dekaliber
Interesting... I wonder if something changed between the production years (but you think that'd be reflected on realOEM). aerobod -- is your car an '07 too?
When I tried the 15mm rivets, the seem to fit a little loosely. Not to the point where they'd fall out or anything, but I could pinch together the wheel well lining and the outside of the bumper and wiggle the rivet loose without popping out the center portion.
      08-16-2010, 02:46 PM   #9
Ron Stygar
From damage they look under 51 bumper and come up with pop rivet 953.
The following shows what you mentioned on 953 (Three item 9's).
http://www.penskeparts.com/DiagramsR...iagram=51_4952
      08-16-2010, 11:46 PM   #10
aerobod
Car Geek
aerobod's Avatar
3626
Yes, mine is a 2007 (March production). 4x 20mm plastic rivets on each side of the bumper to attach the liner.
