09-14-2015, 03:05 PM | #1 |
Rep 23
Questions about puttingg a magnaflow on my 2.5
I want to put a magnaflow 14805 on my 2.5 . When i go to the muffler shop do i just tell them to remove the stock exhaust and install the magnaflow? Also what do you guys think about this particular part on a z4? Im looking for a little more of a power sound .
09-14-2015, 05:15 PM | #2 |
Rep 407
Every muffler shop out there should be able to do what you're asking for. Just tell them exactly what you said above and they'll take it from there.
I took a look at the part# and found the tip diameter is 3.5 inches. That's huge lol. I wouldn't do it but if you really want to I can sell you this exact muffler I have on my e39. I'll be more than happy to get rid of it lol. Do some research on how 3 inch diameter tip looks first. I think you should go with 3 inches. CORRECTION: I have part# 14816. Same thing but the tips extend a little further out. Last edited by UntzUntzUntz; 09-14-2015 at 05:22 PM.. |
09-14-2015, 09:01 PM | #3 |
Rep 23
i was going to go with the 12468 with added tips because i read someone on this forum did it a while ago and it sounded great . But i read he took off a bunch of oher stuff for it to fit. I thought since the 14805 is shorter in overall size muffler wise , it would be the better option. I saw a guy on youtube with it on a z4 it sounded good too
09-14-2015, 09:21 PM | #4 | |
Rep 23
09-14-2015, 09:33 PM | #5 |
Rep 10,645
Magnaflows are good. I had a twin setup on a Z3M of mine years ago and it sounded great for about 1/3 the cost of a name system.
09-14-2015, 11:07 PM | #6 |
Rep 407
Whatever the diameter of the pipe is, do NOT get anything smaller than that size. Assuming the 2.5L z4's have 2.5 inch diameter exhaust piping, do not get a muffler that has a diameter of 2.25 inches, for example. Just not good for exhaust flow.
The smallest ones I can find for Mangaflow's that are 2.5 inch inlets & outlets: - 11379 (satin finish ) - 14379 (polished finish ) Since the outlet of these mufflers are 2.5 inches, you're gonna need tips that go from a 2.5 inch to a 3 or 3.5 inch, whichever one you want. This makes it easier for the muffler guy to install it, for the car to breathe better, and just piece of mind that you did the job the right way. Hope this helps, good luck! |
09-15-2015, 02:54 AM | #7 | |
Rep 23
Also what tips like on summit racing will fit ? Could u post me a link to some good ones that will fit the 14379 Should i remove the resonators too? Will it give it less drone, better sound? Last edited by Z4Oak; 09-15-2015 at 04:17 AM.. |
09-15-2015, 11:55 AM | #8 | |
Rep 407
Positive: - Slightly better exhaust flow, but far from being anything near noticeable. - Less weight. Carry the OEM muffler after you install the Magnaflows. - The SOUND. - You might get a spike in more relationships. Negative: - I don't think it'll be loud enough but it might attract cops. After all, we do live in CA. - You'll drop in MPG because... well... you're gonna be driving a little faster than usual. Regarding the tips, you can find them anywhere. Summit, eBay, Amazon, local Autozone shop, even some muffler shops might have some in stock. As long as the inlet is 2.5" and outlet is 3" (whatever size you want) you're solid. Here's one I found I think will look nice: http://www.amazon.com/Yonaka-Outlet-.../dp/B009R6ZTQ8 Regarding the resonators, it's the resonators that's keeping the car from drone. Keep the resonators in tact and you won't experience any drone. Hopefully someone from the 2.5L family can chime in on this setup. Just a couple tips from my experience: - Don't base your final decision on YouTube videos. You'll be surprised how different they sound in person. - Consult with a local reputable shop just to plot where and how everything will be installed so you don't jump into any surprises on the day of installation. Often times they'll even cut you a deal if you buy the muffler from them so be sure to ask. Last edited by UntzUntzUntz; 09-15-2015 at 02:13 PM.. |
09-17-2015, 07:54 PM | #9 |
Rep 12,565
3.5" tips will be fine. That's what I have and I think they look good. But I wouldn't expect much of a power bump from a muffler swap alone. Your butt may say otherwise but the bottleneck is the cats, not the muffler. You'll save 5-10lbs and get some better flow and sound. Point is do it for looks and sound but not for performance.
09-20-2015, 01:28 AM | #10 | |
Rep 23
09-20-2015, 02:02 AM | #11 | |
Rep 407
The one you read about is probably on an M; maybe even my post, as I have that setup on my car. The M's have a single exhaust pipe leading to each individual muffler while your car has 2 pipes leading to the muffler. You can't have 2 inlets both be offset. Check out this thread: http://www.zpost.com/forums/showthread.php?t=687247 This is what your car is going to look like after you install it, except with a muffler behind those tips. Don't worry, you're fine |
