      07-30-2017, 12:44 PM   #1
roscoesdad
Drives: 2005 Z4
Adjusting clutch switch
My starting has been intermitten. I could press the clutch hard and it would start. Now it will not no matter how hard I press. I have dropped the lower dash and found what I think is the clutch switch. Can it be adjusted or bypassed?
      07-30-2017, 01:21 PM   #2
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Yes you can. Just from the top of my head. Cut the tape, move closer to the steering wheel direction a few mm. Push the clutch in with your hand, you'll hear a click. zip tie it when you find the perfect position.
      07-30-2017, 01:40 PM   #3
roscoesdad
Drives: 2005 Z4
No tape found. Switch snaps into a bracket on the side of the clutch cyl. See no way to adjust that bracket.
      07-30-2017, 02:16 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
FWIW, You can also code it out completely.
This is a N.American safety item, so the usual caveat applies; change at your own risk.
In NCSExpert > goto EWS module
"PARK/NEUTRAL_ENGANG" Start only in Park/Neutral
Change 'aktiv' to 'nicht_aktiv'
      07-30-2017, 05:25 PM   #5
roscoesdad
Drives: 2005 Z4
clutch switch
Thanks, Internet failed just as I pm'ed you. Cheap Verizon service. Sounds like a big job. Probably need to concentrate on adjusting or replacing old switch. Anyone ever replaced the switch with success? Seems there is no way to adjust the old one. Found replacement switches on Amazon for $50. Will do that if I get positive results from others.
      08-02-2017, 03:25 PM   #6
roscoesdad
Drives: 2005 Z4
Replaced clutch switch with new switch. Did not help.
      08-02-2017, 04:08 PM   #7
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
I just took the switch out of the bracket and move it up a little bit. The perfect position for me, the switch is 1/3 higher out side of the bracket. I just zip tie it to that specific location not flush to the bracket. 6 years and counting without any issues.
      08-02-2017, 05:07 PM   #8
roscoesdad
Drives: 2005 Z4
i'll try that. Thanks.
      08-02-2017, 08:05 PM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Are you sure the problem's not your ignition switch?
They do sometimes go intermittent.
      08-03-2017, 07:22 AM   #10
roscoesdad
Drives: 2005 Z4
How do you determine if the ignition switch is bad? Auto is now starting every time. Decided to do this on it's own next day after replacing clutch switch.
      08-03-2017, 10:47 AM   #11
StickMon
StickMon's Avatar
Drives: 2006 MR
Search on "ignition switch".
You could just replace it. It don't think it's very expensive or hard to replace.
      08-03-2017, 03:54 PM   #12
roscoesdad
Drives: 2005 Z4
http://www.pelicanparts.com/techarti...eplacement.htm
From this explaination, it seems like a major job. Can the switch be replaced without removing steering wheel or removing the tumblers. Just asking for info from someone who has made the change.
      08-03-2017, 05:30 PM   #13
StickMon
StickMon's Avatar
Drives: 2006 MR
Well, this would have been helpful, but PhotoPhucket has a ransom on all of the pictures.
      08-03-2017, 07:51 PM   #14
roscoesdad
Drives: 2005 Z4
I agree. Cost $399 to view them.
      08-05-2017, 08:16 AM   #15
roscoesdad
Drives: 2005 Z4
Problem was bad starter, Replaced with 1 from Autozone, $139, lifetime warrenty. Starts everytime. Even sounds different. Thanks for the advice.
inTgr8r2421.50
      08-05-2017, 08:52 AM   #16
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Excellent!
      08-11-2017, 08:42 PM   #17
unluky
unluky's Avatar
7465
I was reading this thread thinking "I bet it is the starter, I wdnt down the exact same list when mine screwed up!". sorry I did not see it sooner. amazing how different the new starter is!
      08-13-2017, 09:30 PM   #18
mousitch
Dark Sider
mousitch's Avatar
127
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Has ncs gotten any easier?
Haven't used it since turning on three blink and recoding amp. All the software is on an old laptop that I'm sure is trash. Do they have any apple based ncs yet or just windows based?
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert settings
      08-14-2017, 07:38 AM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I cleaned up an old laptop to nothing but run car software.
I'm not an Apple guy, but IIRC guys have run it under bootcamp.
