Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      05-25-2016, 04:22 PM   #23
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
For all you guys with Canadian spec cars, I had the chance to compare and change the coding on Caddyshk's car.
I think everyone is aware that BMW in their infinite wisdom turned on all the running lights and Xenon L. beam as DRLs.
Basically the only thing different between headlight switch 0 and 1 is that the interior gauges are not on in pos. 0
....evan the license plate light is enabled as DRL
OK.... here is the coding change needed for you CDN spec car owners.
Coding is in the LCM
there are 2 lines that need to be changed.
1. DAUERFAHRLICHT_US translation; Daytime Running lights USA
CDN car is coded to aktiv
change to nicht_aktiv
2. PO_ALS_DRL translation; Position lights as DRL (bumper sidelights)
this will leave just the inner angel eyes "on" as DRL
****this was done on Z4M, not sure how this applies to Z4
okay...I have read this a few times, yet fail to 'read' what is different.
So are you saying after you code this all makers lights run as DRL? And the 'ring' is the only item on the headlights? Not the actual xenon bulb....??
Sorry for being a dunce, but somehow I can't figure out exactly what is different.
Probably as I have a US Spec car that had the DRL lights turned on and all I have is the xenon light on at maybe 60% or so.
So I'd actually like all the marker lights on, and perhaps just the 'ring' on. BTW...I have an 06 Z4...
Thanks,
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      05-25-2016, 09:31 PM   #24
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks,
For option 1 coded as "activ", all the external lights are on, exactly as if you turned on the headlights at night.
That's how CDN spec cars are coded.
Most of us want all those extra lights off.
US spec has only the inner angel eye as DRL and nothing else.
If you have the xenon on, someone made a change when the car was imported.
(My car is also US import)
I'm not sure it's possible to do what you want; have everything except the xenon.
The 2nd one turns on the bumper round markers as DRL
...hope that helps.
      03-28-2019, 08:32 PM   #25
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Originally Posted by Mirko View Post
Any way to turn off both of the orange lights below the headlights? I can do one of them but not both using Carly for BMW. I think there is an option to turn it to Euro setting that would do it but never could find a complete answer.
Did you ever figure out how to code off both standing/orange lights below the headlight?
Im doing morimoto halos retrofit they have two colors white witch is connected to DRL and orange witch is should be getting signal from turn signal but since turn signal in our cars is also standing light it cousing me problemm so I decide to code off them.
Thanks in advance
