Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      05-17-2016, 06:24 PM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Smile Canadian DRL running lights coding - Done
For all you guys with Canadian spec cars, I had the chance to compare and change the coding on Caddyshk's car.
I think everyone is aware that BMW in their infinite wisdom turned on all the running lights and Xenon L. beam as DRLs.
Basically the only thing different between headlight switch 0 and 1 is that the interior gauges are not on in pos. 0
....evan the license plate light is enabled as DRL
OK.... here is the coding change needed for you CDN spec car owners.
Coding is in the LCM
there are 2 lines that need to be changed.
1. DAUERFAHRLICHT_US translation; Daytime Running lights USA
CDN car is coded to aktiv
change to nicht_aktiv
2. PO_ALS_DRL translation; Position lights as DRL (bumper sidelights)
this will leave just the inner angel eyes "on" as DRL
****this was done on Z4M, not sure how this applies to Z4
      05-17-2016, 07:49 PM   #2
kav
Drives: Z4M
How did you do the coding?
      05-17-2016, 09:48 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I used NCS Expert
      05-17-2016, 10:54 PM   #4
kav
Drives: Z4M
Originally Posted by inTgr8r
I used NCS Expert
I haven't heard of this software.
What sort of other changes are possible on our cars?
      05-18-2016, 08:43 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
There are tons of things that can be changed.
There are several threads posted here on the coding topic.
      05-18-2016, 12:25 PM   #6
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
is this a time consuming task? my M is from the usa and when it was imported bmw canada did the configuration- as u said every light is on!
      05-18-2016, 12:28 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No, it doesn't take long at all.
Less than 30 min including setting up, doing backup etc.
      05-18-2016, 01:15 PM   #8
Huz-Z
Huz-Z's Avatar
My car was a US 3.0si that I imported into Canada. Although the dealer down there agreed to enable the DRLs for Canada, he messed up and set them to the US version of DRL, meaning that only the halos light up on my car when the engine is running and the light switch is in the OFF position.
But I actually prefer this. First, for a car with fog lamps - and as I live out east where we get pea soup thick fog - I can now run with the headlights OFF but the fog lights and taillights ON. Which I think is MUCH better.
With the Canadian situation, the headlights stay lit while the fog lights are on, and you get all that glare back in your face.
Huz-Z
      05-18-2016, 04:43 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Very good point.
Having the headlight glare in fog would suck.
      05-19-2016, 07:54 PM   #10
Mirko
Mirko's Avatar
Any way to turn off both of the orange lights below the headlights? I can do one of them but not both using Carly for BMW. I think there is an option to turn it to Euro setting that would do it but never could find a complete answer.
      05-19-2016, 08:56 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Do you mean when headlights are 'ON' ?
Yeah, it's a little funny.
On the euro setting one of them doesn't come on with lights ....forget exactly.
I think it's doable, I just need some play time on it.
      05-19-2016, 09:00 PM   #12
Mirko
Mirko's Avatar
I think it is the inner one that shuts off with the outer one still on.
It's odd that with my e90 I can turn off the turn signals with the headlights on. They only blink when in use. Car looks cleaner and nicer that way. Wish we could do that with the Z4M.
      05-19-2016, 09:19 PM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I think it's doable with a little digging.
      05-20-2016, 10:24 AM   #14
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Single benefit to having a Non-M 2003 Z4 with Xenon package....
...my high beams (flash to pass) are my DRLs
      05-21-2016, 01:00 PM   #15
kav
Drives: Z4M
I've got an American M coupe I bought new.
I've always hated the way the full lights come as the DRL. Would you consider a price for reprogramming for locals?
      05-21-2016, 03:50 PM   #16
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
US cars use the inner angel eyes as DRL.
Did you take the car to a CDN dealer as part of the import process.
Do your other running lights also come on?.
If you want to make the drive I can help you out
I'm not concerned about $
      05-21-2016, 06:40 PM   #17
kav
Drives: Z4M
When I brought the car over it went to the dealer and thinly "re-coded" it to be a Canadian settings vehicle. They actually claimed to get a file from BMW NA. The switch doesn't do much and the headlights and inner fog lights are on as the DRL.
      05-21-2016, 07:22 PM   #18
mtnbkr
mtnbkr's Avatar
Drives: '06 IB Z4MC
I turned these ones to "nicht_aktiv" to turn off the amber lights and the rear red bumper dot.
PO_ALS_DRL - POSITION LIGHTS AS DAYTIME RUNNING LIGHTS (seems to turn off outer head lamp?)
PIN_20_37_ALS_PO - inner amber lamps
SL_VO_ANSTEUERUNG - FRONT STANDING LIGHTS CONTROL (outermost upper amber lamps, rear bumper red "dot")
SIDEMARKER_US - USA SIDE MARKER LIGHTS (outer lower amber lamps)
Set the following to "wert_01" in the LSZ module
LAENDERVARIANTE_LSZ - COUNTRY VARIANT LIGHT SWITCH (LSZ)
Thinking of turning off the xenons for DRL but the angel eye light is so dim and weak!
      05-21-2016, 07:33 PM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
When I did PO_ALS_DRL it just did the round bumper lights as DRL, but they still work with the lights ON. (Same on 3 cars)
Good info on those other settings, I haven't taken the time to investigate those.
      05-22-2016, 01:18 AM   #20
Cyclops
Cyclops's Avatar
After seeing this definitely need to do some light coding, did realize DRL on the tail lights.
- Instagram ->@e91kiter
      05-22-2016, 08:07 AM   #21
Polarbert
English Member
25
Drives: 2006 Z4M Roadster
Can anyone point me in the direction of a decent guide to using ncsexpert? I've tried looking into it before and couldnt get my head around how to do it. I really want to disable the bloody annoying beeps when the key is in the ingnition.
      05-22-2016, 09:55 AM   #22
Cyclops
Cyclops's Avatar
It's been a few years since I did the actual install but you'll find lots of info in the coding section of E90post.
http://www.e90post.com/forums/showthread.php?t=451145
