05-20-2022, 07:27 PM | #1 |
Rep 2
Top problems
Hi I've got a 2003 E85. They other day when I go to lower the top it wouldn't move. It unlatches fine. I hear the motor spinning but the top dosen't move. So I pull the red (handle) wire in the trunk and lower it by hand. Then I put the Handle back in its normal position and try closing the top. It closes normally, but when I try and open it. Same thing, motor kicks in normally but the top does not move. It will not open. Any ideas?. Thanks
05-22-2022, 03:39 PM | #2 |
Rep 158
Hey Mike
The top is releasing from the windshield frame and then stopping dead in movement but....you can still hear the motor running. Is this correct? If so, then push top down and after the top stops movement get out of the car and WITHOUT using the red release in the trunk try pushing the top down. If you can do it then try putting the top up, again WITHOUT using the red cable. Then post the results, in that can you cycle the top down/up without using the red release. |
