05-14-2022, 02:21 PM | #1 |
Rep 783
Air bag light
I have had an airbag light on between the tach and speedo since I bought the car, I found my way into the body diagnostics and there were the following 4 codes.
93B2 safety battery terminal 93A9 control module fault 93C8 deactivation switch center steering column 93C9 deactivation satellite A pillar left From some reading up on these I've found that they might not be the problem at all, it could also be anything else in the SRS, the seat belt receiver, the seat occupation sensor or even the front impact sensors. Do I just start replacing components until it is resolved? Is there any way of testing without blowing airbags? Thanks
2008 E86 M coupe
05-14-2022, 02:47 PM | #2 |
Rep 70
ISTA can clear airbag fault codes. Somebody probably removed seat or steering wheel while battery was plugged in.
grannyknot953.00 |
05-14-2022, 08:19 PM | #4 |
Rep 783
I ended up not using the M3 wheel but instead found a standard Z4 wheel that uses the original airbag.
2008 E86 M coupe
