11-05-2014, 09:04 AM | #1 |
Rep 91
Extreme inner shoulder tire wear
Hi All,
This year I lowered my Z4M on eibachs, installed turner camber washers and aligned to zero toe in the front and slight toe-in in the back. Camber ended up at -2.8 in front and -1.9 in back. I added a strut brace and 12mm spacers in front to widen the track. Looked good and the handling was improved by an incredible amount. I made three trips to the tail of the dragon and had a blast. I ran tire pressure at 33 lbs front and 31 lbs rear. I regularly checked for uneven tire wear, measuring outer grooves and inner grooves with a tread depth gauge. Only slightly more wear at the inner groove and no unusual outer shoulder wear. Then I found this: Extreme wear on the inner shoulder. Down to the cords so far down the side of the shoulder, it is almost the sidewall. Scared me just to see it, especially when I considered what a tire failure would mean at 120 mph on the skyway. So, needless to say, I'm looking for a good street alignment set-up instead of maybe a track set-up. I have new tires and wheels installed, and swapped from two washer spacing to one washer in the front. I raised the rear 10mm in hopes that raising it slightly will help decrease some of the negative camber I gained when lowering, and I'm ready to head off to the alignment shop. I'm hoping for some discussion and opinions on what I should shoot for and also if I'll need adjustable rear control arms to achieve it. Also wondering if I may be over inflating tires although nothing found to support this. Finally, am I missing something completely as in a worn part causing this? Car has 51K miles and everything feels tight. |
11-05-2014, 11:24 AM | #3 |
Rep 11,667
- is that wear in front, or rear?
- how many miles with that setup? - slight rear toe; do you know the #s ? I have a more extreme setup than you & have no such wear issues. worn out bushings are the first thing that comes to mind, but I would expect more cupping.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 11-05-2014 at 11:39 AM.. |
11-05-2014, 12:58 PM | #4 |
Rep 91
Hi, The tire shown was the left rear. The other rear was almost identical. The fronts were showing bad wear as well. rear toe-in was less than 1/16. All this uneven wear happened within about 4500miles. A dozen hard runs on the dragon, at least 4 skyway runs pushing hard, and numerous trips on hellbender 28. I have gone a couple times a year on my hayabusa for ages and this time my son brought his new GSXR1000. I just want to figure out how to use the rest of the tire so I can go faster (ha ha). Seriously, we both looked over suspension front and rear and saw nothing obvious. If my toe settings were responsible, I'd expect the top of the shoulder to wear rapidly, but only 1/32nd" difference from outermost groove to innermost. It seems as if several guys are running specs at least this extreme, so I'm concerned there are worn parts I'm missing.
11-05-2014, 03:52 PM | #5 |
Rep 2,138
Drives: Me
11-05-2014, 05:11 PM | #6 | |
Rep 11,667
Almost guaranteed to be the RTABs
11-05-2014, 05:35 PM | #8 |
Rep 91
Thanks for the input. Time to replace asap before I waste an alignment. Should I replace with stock parts and use limiters, or is there a better upgrade? What about adjustable control arms: needed or not?
11-05-2014, 11:22 PM | #9 |
1821
Rep 5,337
How often do you track the car?
11-06-2014, 06:23 AM | #10 |
Rep 91
Maybe twice a year. Remaining use is 30% easy country cruising with the wife, 30% getting to the mountains, and 40% very hard mountain driving. So I can't have a track only set-up. I've made the mistake of going too far down the performance only set-up before, but have also conditioned my favorite passenger to expect and enjoy a sporting ride. If it is coming apart, I want the replacement parts to be more performance focused. Thanks!
11-06-2014, 06:54 AM | #11 |
Rep 11,667
I went with the R.Eng black poly RTABs which are a little softer than a full out track bush.
They have been great for me on a combined usage car. I would buy them again. there is some interesting info on the linked page.
11-06-2014, 08:19 AM | #12 |
1821
Rep 5,337
That's a lot of camber for a car that only sees 2 track weekends a year.
11-06-2014, 09:59 AM | #13 |
Rep 2,866
11-06-2014, 10:21 AM | #14 | |
Rep 91
Camber setting
With that said, my settings are definitely in the track realm and may not need to be this extreme, which is one reason I'm asking for advice. Plus the rear camber is simply what I ended up with when I lowered the car. Then there is the worn part issue, and finally what settings I shoot for will help decide if I need adjustable lower arms and so forth. Thanks for sharing your thoughts and experience. |
11-06-2014, 10:38 AM | #15 | |
Rep 91
rear camber
My front tire wear was also right on the inner edge of the tire, just not as extreme. I'm thinking of FCAB upgrades as well after doing a few searches and reading. The car seems to corner pretty flat, but maybe I need to explore sway bars or end link upgrades too. |
11-06-2014, 11:08 AM | #16 | |
Rep 91
RTABs
I did also find something on B'world that was supposedly a streetable monoball type. I'm considering putting off replacement until January when I won't miss any chances to drive due to winter weather anyway. So I may go ahead and align the car, see how much negative camber I can dial out and drive easy until then. I did just buy a new set of pilot super sports and don't want to risk them! |
11-06-2014, 11:55 AM | #17 |
Rep 11,667
absolutely no binding or noise after a couple of years usage.
I also have poly FCABs and they have been great as well. BTW... Envious of your location near those great driving roads. Some of the best I've ever driven! Cherohala
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 11-06-2014 at 12:01 PM.. |
11-06-2014, 01:00 PM | #18 | |
Rep 91
You're always welcome to come visit again! |
11-06-2014, 07:34 PM | #20 | |
Rep 91
There has to be some serious deflection going on when under heavy load. I'm definitely replacing the RTABs and wanting to add poly bushings to the lateral control arms as well. |
11-07-2014, 01:49 PM | #21 |
Rep 279
I've been running the BW spherical rtab's for about 10k miles and really like them. I also did the rear ball joints at same time and rear is very stable now under hard braking/turning. My car is also a back/mnt. road car but driven pretty hard. I run -2 rear camber and have no significant inner wear. Before the sphericals I could really feel the rear end squirming around with the stock bushings after 10k-15k miles.
06 Alpinweiss Z4M R Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake |
11-07-2014, 08:48 PM | #22 |
Rep 91
I was hoping someone would post up with some experience with the BW spherical RTABs. I'm leaning that way now. Always liked the idea but worried about harshness. Wondering about lateral control arms. I did also decide to go with poly FCABs in the front. Thanks!
