      04-27-2013, 04:31 PM   #1
Z4MGTO
Drives: '07 M Roadster/'06 GTO
'07 BMW Z4 Light Bulb Size Guide
I tried searching for this on the forum but didn't really come across anything. After a little further searching I found this:
2007 BMW Z4 Car Light Bulb Size Diagram
Low Beam Headlamp Light Bulb Size: H7 or H7 HID Upgrade Kit
High Beam Headlamp Light Bulb Size: H7 or H7 HID Upgrade Kit
Parking Light Bulb Size: 2825LL
Front Turn Signal Light Bulb Size: H21W (64136)
Rear Turn Signal Light Bulb Size: 7507AST
Tail Light Bulb Size: 7528
Stop Light Bulb Size: H21W (64136) or 7528
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: H11 or H11 HID Upgrade Kit
License Plate Light Bulb Size: 2825
Back Up Light Bulb Size: 921LL
Front Side Marker Light Bulb Size: 2827
Map Light Bulb Size: 2886X
Dome Light Bulb Size: 2825
Step/Courtesy Light Bulb Size: 2825
Trunk/Cargo Area Light Bulb Size: 6411
I figured someone might get some use out of it, as I did.
'07 ///M Roadster - Black Kidney Grills - 19" CSL Reps - Rogue El Diablo Exhaust - Black Roundels - Stubby - More to Come
'06 GTO - All Show, All Go
      04-27-2013, 08:49 PM   #2
chickdr
Drives: 2006 M Roadster
The brake light bulbs are also known as "1156" which is a single filament type. i just put 1156 Can Bus LEDs in mine. The trunk cargo area is a "194" as well as the side turn signals, outer side marker lights in the headlight cluster and license plate lights.
