09-14-2016, 11:17 AM | #1 |
Rep 10,723
Tire sizes with 19x8.5 +30, 19x10 +22 wheels.
Hi there. I've searched a bit, but can't find much on my particular situation. I'm currently running 19x8.5 +30, 19x10 +22 with 245/35/19 and 275/30/19 tires, along with H&R coilovers on my Z4M. I'd like to keep the front tires the same size, but would really like to get a 285 or maybe even a 295 in the rear. Do you think a 285 or 295 sized tire, say 285/30/19 would be an ok fit in the rear with a 19x10 +22 wheel? As it stands right now with my current setup, the car is pretty low and I haven't had a single rub ever.
Please keep in mind this car is for the street, and I'm not interested in how fast it can go around some orange cones, that I'm messing up the balance, or that I have less of a contact patch now or something. I just like the look of a fat rear tire, and appreciate any feedback you might have regarding if a wider tire will fit or not with no other modifications. Thanks a lot. |
09-19-2016, 03:17 AM | #3 | |
707
Did you check the wheel fitment spreadsheet? Last edited by Finnegan; 09-19-2016 at 03:25 AM.. |
NickyC17652.50 RedOctober32.50 |
09-19-2016, 09:56 AM | #4 |
Rep 10,723
Thanks Finnegan. Yeah the more I look, I don't think anything over a 275 is really going to be possible. Just looking at my car, the sidewall is nearly at the fender so I doubt it's going to work. It's cool, just thought it might be nice to get some wider tires back there, but I'm sure not going to mess up what's a great setup right now.
Thanks again. |
09-19-2016, 11:05 AM | #5 | |
Rep 11,669
It also makes a HUGE difference on the tire brand used as to how rounded the shoulders are. e.g. 265 Hankook RS3 vs ZII star specs section width is identical @ 10.7 Tread width is VERY different. 9.4 vs 10.0
09-19-2016, 11:12 AM | #6 |
Rep 10,723
Ok, thanks as well inTgr8r! Moving up a single tire size then just isn't worth the hassle, no problem. Thanks for your help guys!
09-19-2016, 11:34 AM | #7 | ||
707
09-19-2016, 03:50 PM | #9 |
Rep 10,723
10-17-2016, 09:02 AM | #11 |
Rep 10,723
10-17-2016, 10:03 AM | #12 |
Rep 2,877
Currently running Continental DW (275/30/19). I was wondering about fitting 285 (same DWs to be safe) onto my 19x9.5 et 25 wheels as well (for better rolling diameter matched to the front 245/35/19) on the next set. This weekend, I had tried to place full or close to full compression on the rear and saw about 10mm space available to the fender. Inner clearance is a bit more at about 15mm. I'm on standard suspension with no fender roll.
Looking at specs on TireRack, I had noticed that going from 275 to 285 (same Continental DW), the section width gained 0.5", which may make me rub slightly at compression, but I was surprised to see that you'll actually lose 0.1" in tread width? This doesn't make sense and had me wondering how accurate are the measurements from TireRack in reality? If that's really the case, I'll be shooting myself in the foot for losing contact patch going to a wider tire? I think this experiment may sway me to stay at 275 and leave some wiggle room for size width variations between tire manufacturers/models in the future. |
10-23-2016, 01:39 AM | #13 |
Rep 924
I feel like a grounded teen on party night while the Porsche guys are getting all the action in the back.
10-23-2016, 10:43 AM | #14 | |
Rep 758
http://www.tirerack.com/tires/tirete...jsp?techid=201
Top Down 365
XMetal1148.00 RedOctober32.50 |
01-10-2017, 08:59 AM | #15 | |
Rep 453
Drives: 2007 Z4M Coupe
