      11-24-2014, 02:31 PM   #1
jaconley
Drives: 2007 M Coupe
Replace Z4 Coupe Door Gasket
Does anyone know how to replace the door weatherstrip? I didn't find a procedure on the TIS CD. The part number is 51333420703; #1 on the below diagram.
http://www.penskeparts.com/ShowImage...&rnd=203042259
      11-24-2014, 02:41 PM   #2
C-los
Drives: 2013 M3
Normally, the door side weather strips either
a) sit in a run channel,
b) use a type of 'T' clip that snaps all around the body
c) combination of both
Body side weather strip normally is pressed (or tapped lightly with a rubber malet) on the pinch-rail.
      11-25-2014, 09:26 AM   #3
jaconley
I believe I'm going to have to remove some trim pieces first. I found some instructions on removing some of the trim pieces on the TIS CD. I'll just have to dive into is a learn what trim pieces need to be removed.
      11-25-2014, 10:39 AM   #4
C-los
Drives: 2013 M3
Not normally, My car is in the shop so i don't have access to it atm or i'd look at it really quick for you :/ sorry
