      04-16-2016, 05:57 PM   #1
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
Gap in front anti roll bar bushing
So last year I replaced my struts, LCA, and front ARB bushing. I was swapping over to new wheels today and notice that there is a gap about 1/8" between the bushing rubber and the ARB. Is this normal? Should I replace with poly bushings? Why did the bushing fail in only a year?
      04-16-2016, 06:54 PM   #2
Steeler
Steeler's Avatar
2429
Did you put on the correct ARB?
Your sig does not say which model Z4 you have.
      04-18-2016, 08:16 AM   #3
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
I have a 2007 3.0i roadster w N52.
The ARB is stock, I just replaced the bushings with some from the BMW dealer.
      04-18-2016, 11:12 AM   #4
Steeler
Steeler's Avatar
2429
Sorry I should have said ARB bushing
They may have sold you a bushing for an M or for a car with M suspension. 1mm difference in bar diameter
      04-18-2016, 04:02 PM   #5
Big_CG
Big_CG's Avatar
185
Drives: 2020 X5
My car does have the sport package-
It looks like I need the 25mm bushing per real OEM. Am I correct in thinking there should be zero gap between the ARB and the ARB bushing? I will probably upgrade to the polyurethane to prevent further wear.
      04-18-2016, 06:57 PM   #6
Steeler
Steeler's Avatar
2429
Any time I have replaced ARB bushings there has been a gap at the split once wrapped around the bar. It tightens up as you torque the bracket down. So no there should not be a gap between the bar and the bushing.
The poly bushings will have a packet of lube supplied.
I always throw some white grease on mine to grease them up.
I think even if you went with the 24mm bush you would not have an issue and you would definitely not have a gap.
I can't believe a new bushing has worn out in one year.
      04-19-2016, 06:57 AM   #7
Drives: M2 Comp
^ I agree
