09-16-2013, 03:55 PM | #1 |
Rep 2,704
3.0i resonator delete
So I have searched all the threads regarding deleting the resonators and stock muffler and adding an aftermarket muffler which in most cases is the Magnaflow.
Can anyone give me a good reason why the aftermarket muffler can't be in the stock location still removing the resonators and going straight pipes from the cats to the muffler? Is the location of the muffler close to the engine the reason for the improved sound?? Would the sound be different with the muffler at the very rear of the car??? Would there a performance improvement with a longer run before the muffler???? I would be interested to compare the difference between 2 round mufflers, a 2 in 2 out muffler as well as a crossover muffler like the Dynomax 17552 muffler I realize there would need to be some fooling around with the tips but that is not too difficult. Thanks Dave
09-27-2013, 04:56 PM | #2 | |
Rep 2,704
Is it a stupid question?"........go ahead I can take it. Dave
09-27-2013, 06:23 PM | #3 |
More of this than that!
29
Rep 817
Interested as well...I have a 3.0i as well, and would like a bit more growl...without doing a complete change. If I can remove the muffler or cats...would either be more 'sound' without sounding too harsh, or ricey?
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
10-06-2013, 07:25 PM | #5 |
Rep 1,224
There is a number of threads that touch on this topic without actually addressing your question, suggest reading through the various muffler threads for some history/depth. Some threads listed below overlap and link back to one another but will contain some good info hidden in the discussions. If you do decide on a mod, post your work. Many of us are still in search of cost reasonable options. Good luck.
http://www.zpost.com/forums/showthread.php?t=843302 http://www.zpost.com/forums/showthread.php?t=687247 http://www.zpost.com/forums/showthread.php?t=800085 http://www.zpost.com/forums/showthread.php?t=687247 http://www.zpost.com/forums/showthread.php?t=736365 http://www.zpost.com/forums/showthread.php?t=607479 http://www.zpost.com/forums/showthread.php?t=529926 http://www.zpost.com/forums/showthread.php?t=475488
10-06-2013, 07:52 PM | #6 | |
Rep 2,704
Yea I've been through the posts more than once looking for any info that might give me an idea of the sound I will get
My main question is if I remove the resonator run straight pipes back to a performance muffler will I get more or less db's as compared to a performance muffler replacing the resonator and straight pipes back. Seems more of an engineering type of question than a "who's done it" type of question. Quote:
10-07-2013, 11:05 AM | #8 |
Rep 2,704
Absolutely, but replacing with aftermarket at that location or putting in place of the resonator is the jist of my inquiry.
10-07-2013, 01:15 PM | #10 |
Rep 541
Drives: 2022 X3MC
I was going to go the MagnaFlow Route via Angry Cop style, but that part would not fit inbetween the firewall. It hung below the car too much so I just did a muffler delete.
So I did muffler delete but left the stock 2nd resonator. Let me know if you need any clips. Love the increase in dB and the "gurgle"
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
10-07-2013, 03:23 PM | #11 |
Rep 2,704
A sound clip would be great thanks
10-07-2013, 04:40 PM | #13 | |
Rep 2,704
That opens up the option of reworking the innards of the stock muffler so no new pipe work is needed, it has been discussed at length and done on many M's.......might be time to do a 3.0
Looking forward to those sound bytes pyo Quote:
10-07-2013, 05:03 PM | #14 |
Rep 192
I would only want to change out or just completely take out the muffler and add in straight pipes.
Here is just a straight pipe. And here's a Magnaflow. |
10-08-2013, 01:04 PM | #15 | |
Rep 541
Drives: 2022 X3MC
Anything specific you are looking for in the clip? The 2nd vid Exist posted above me is what mine sounds like. EDIT: Found an old clip when I first got it done. Car was still in that garage, so it may be a little louder than it really is.
'00 328i // Sold
10-09-2013, 07:39 AM | #16 |
Rep 228
I would propose without 100% knowing for sure that running pipe all the way back will result in more drone than putting the muffler in the middle.
I've replaced my 2nd cats with a magnaflow and run pipes straight back - I love it
bags are for groceries. |
10-09-2013, 11:56 AM | #18 | |
Rep 2,704
Thats fine, really interested in what the sound difference would be with a longer run of straight pipe to the muffler with the resonator removed or with the resonator moved to the end of the run.
I had a trans am back in the 70's and did a dual muffler delete and replaced with resonators, it sounded awesome but we are talking difference animals. May have to mock up both ways over the winter and see what turns up. I am a steel fabricator by trade. Quote:
