      07-22-2014, 01:37 PM   #1
E92M3Pilot
E86MPilot
Drives: F10 550XI
Authentic BBS RGR 19 inch Diamond Black wheels for Z4M
For sale is an Authentic BBS RGR 19 inch Diamond Black wheels, come with Special Edition BBS Red/Gold caps or black/silver, Michelin Pilot Sport A/S tires are mounted on with only 7K miles, and it has lots of threads left 75-80%. Mostly driven on Highway between PA and NJ. It's one of the lightest 19 inch wheels available from BBS.
I had these wheels on my Z4M Coupe on factory alignment""" Looks was awesome. It had a little bit of rubbing on the rear tire during high speed hump, but a small negative camber or roll should solve the issue.
Pictures attached http://www.cars.com/vehicledetail/de...4735/overview/
http://www.zpost.com/forums/showthread.php?t=629084
http://share.shutterfly.com/share/re...Bbs2jFoxZs2rww
Total asking price $2500.
Here are the spec from Tire racks:
Front Fitment
19x8.5
$1,070 (each) New
Offset: 32mm
Backspacing: 6.06"
Bolt Pattern: 5-120
Rec. Tire Size:245/35-19
Weight: 20.3lbs.
Rear Fitment(my offset is 20mm)
19x10
$1,155 (each) New
Offset: 20mm
Backspacing: 6.49"
Bolt Pattern: 5-120
Rec. Tire Size:275/30-19
Weight: 22.0lbs.
E46M, E60/545I, E36/Z3M, E92M DTC, E93M 6spd, E86M(x2), F10 550XI (S2)(Current)
      07-28-2014, 10:41 AM   #2
E92M3Pilot
E86MPilot
Drives: F10 550XI
Bump... pictures added
      07-30-2014, 02:53 PM   #3
E92M3Pilot
E86MPilot
Drives: F10 550XI
bump..
Tags
bbs rgr 19 inch diamond black
