      01-23-2014, 06:56 AM   #1
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Question about Remus exhaust and SS center pipe for 3.0si
I've searched a few sites and can't find an answer. The SS centerpipe I read will bolt-on to car and I'm sure it's made to bolt on with the SS exhaust, but curious to know if anybody has done the centerpipe with Remus exhaust and if so was it bolt on or was a muffler shop needed to fabricate and weld the 2 together. I'm dead set on Remus just was curious if I could order this up and bolt it on in addition. And this for a 3.0si coupe not an M. Thanks!!
      01-23-2014, 03:25 PM   #2
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Anybody?
      01-24-2014, 07:25 PM   #3
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Which center pipe are you talking about (part #)? AFAIK, both the Supersprint Y-pipe and Supersprint catted S-pipe require cutting. The Y-pipe merges two pipes into one, so it will not fit with Remus mufflers. The only other midpipe is a catted S-pipe, which I don't know why you would do unless you had aftermarket catless headers. The HJS cats Supersprint uses are overkill ($$$) for a NA street car, but really show their worth on FI or track applications.
      01-24-2014, 08:51 PM   #4
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Yea after looking closer now that you pointed out it merges two to one, and remus keeps the two pipes. Initially I wanted to do the secondary cat delete and put the magnaflow resonator and run straight pipes from there, only problem is no shop I've been to in ny won't remove any cats because if legality issues blah blah blah. I was under the impression that the SS pipe was removing the secondaries. This is what the center pipe looks like, and the part number is 022 788 113 , but as you said its kinda useless, thanks man much appreciated
