      05-16-2013, 11:57 PM   #1
v8z4
Drives: 2003 Z4 roadster
Supercharged 383 LS6/T56 in Z4
I had posted this over on Bimmerforums and Z4-forum, but forgot to post it here. Currently in the process of assembling a 427CI/7.0Liter LS7 and a T56 into a Z4.
pictures:
the car:
the engine:
the transmission:
the rear end:
Chris
      05-17-2013, 12:04 AM   #2
v8z4
Here's the pictures/writeup from the M3 diff install. The diff install itself was direct bolt in (well obviously since BMW designed it to be interchangeable with the E46 rear).
I opted to machine the M3 diff cover rather than buy a new Z4M diff cover ($250 + shipping from Germany and 2 weeks wait). I just marked (actually sprayed bluing over the rear cross bars) where the bars would hit, mounted the diff cover in the mill, and removed fins as necessary. End result gives plenty of clearance while retaining more cooling capacity than the Z4M cover (not to mention I'm $250+ shipping ahead).
While I was swapping, I also converted from "BMW specific" steel braided brake lines to standard steel braided lines with -3AN fittings and lengthened by a few inches. This way I'm prepped to convert to Porsche calipers in the future.
I also scored a set of Eibach Pro-Kit springs a local guy was dumping ($50). He had purchased them new, never installed them, and traded his Z4 for a new 5 series. So being stuck with a set of "worthless" springs, he just wanted them gone.
The hardest part was getting the stock 5 speed drive shaft shortened. Not surprisingly, the drive shaft tube it's a metric pipe (so standard 1310 yoke ends won't fit it) and nobody around Phoenix has the flanges necessary to grab a BMW year diff yoke. I had to machine an adapter sleeve to convert the metric pipe ID to an American 1310 drive shaft yoke. Then I had to machine a hub for the drive shaft shop to be able to grab the rear flange.
In the end, it took a week of head scratching/trying different options, a half a day of machining parts, and 30 mins. for them to actually shorten/weld/balance the shaft. :rofl:
So, some pictures:
Most places they just swipe your rims/tires, around here they take the whole rear axle. :P
All in, ready to go.
Modified M3 Diff Cover:
Update: I was asked how to avoid buying a Z4M shaft (save money) and also avoid changing the pinion yoke/flange like I did. So, I suggested the following:
Start with the stock Z4 drive shaft (either 5 speed or 6 speed, whichever transmission you have), get a used M3 drive shaft (does not matter from what car). Cut the back flange off the Z4 shaft (in the straight section, stay away from the tapered/necked down area). Cut the M3 shaft (cut it long to be safe) so you have the diff end CV joint section. Make an adapter sleeve from steel bar that has steps, one end for the Z4 shaft, the other end for the M3 shaft (see picture):
The ID/OD interface needs to be around 0.005" press fit (is what I'm told by drive shaft shops and is what I used on my shaft).
Chris
      05-17-2013, 12:51 AM   #3
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Awesome build! Looking forward to following it!
      05-17-2013, 02:07 AM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Holy cow!
      05-17-2013, 07:47 AM   #5
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Please keep us posted, and good luck!
      05-17-2013, 08:07 AM   #6
ricanbandit
ricanbandit's Avatar
28
Drives: 2011 30i
Wow! I wish I had the mechanical ability to tackle something like this. Please keep us posted
2011 30i
[SIGPIC]/SIGPIC]
      05-17-2013, 08:25 AM   #7
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I wanted to do something like this instead of supercharging, but the open checkbook approach scared me away
      05-17-2013, 09:10 AM   #8
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
how and the heck did you keep this under your hat for a year??
/subscribed
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      05-17-2013, 11:02 AM   #9
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6153
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Awww yeah, can't wait to hear how awesome this is going to sound! Love American v8 noise
      05-17-2013, 11:32 AM   #10
v8z4
I kept it on the DL until things started really rolling. Because I didn't know how long it was going to take to be able to fully afford the project, I didn't want to be "well... one of these days I'm going to do it.....".
Want to see something crazy cool, read what this guy is doing: http://ls1tech.com/forums/conversion...ls1-build.html
Chris
      05-17-2013, 11:49 AM   #11
jra
Drives: 2005 z4
staying tuned...
      05-17-2013, 01:15 PM   #12
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
dude you are the man
sub'd
///M - Some Mods 'N Stuff
      05-17-2013, 01:52 PM   #13
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: '17 C2, GTI, Z4 3.0si Racecar
Great project!
I know from reading enough of these swaps that the biggest issue is computer controls for the car vs. the engine.
I seriously thought about swapping an LS7 into my e90 330 and it basically came down to the fact that it would be "impossible" due to the computer issues. A local shop who is REALLY good at doing stuff like this said the "impossible" can be done, it just costs more
Good-luck!
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      05-17-2013, 01:54 PM   #14
dre99gsx
Drives: 1994 Toyota Supra
Engine sump clearance issues up front? Or still TBD?
      05-17-2013, 04:44 PM   #15
v8z4
Originally Posted by TSM330i View Post
Great project!
Good-luck!
I'm ditching the entire BMW ECU and running the LSx off of the GM ECU. I'm working with some guys over on Bimmerforums to create a CANBus interface that will take the GM tach/speedo/temps/etc. outputs, put them onto the CANBus, and drive the gauges/AC/etc. We think we have it all sorted out (or mostly sorted out), but none of us have a "driving" car yet to test with (we either have stock setup still/me, cars that don't run/blown BMW engine, or are in the middle of the project/pulled engine but nothing finished yet).
Worst case I am willing to ditch the factory gauges and build a new cluster around aftermarket gauges.
Well I'm using a dry sump setup (LS7 pan and remote oil tank) so the sump is smaller, but numerous individuals have installed LS1s into E46s using camaro pans. In order to hit the shifter hole in the tunnel, the engine/trans will have to sit back 3" behind where it does in an E46, so oil pan clearance should not be an issue either way.
Chris
      05-18-2013, 11:37 PM   #16
Blind32
Blind32's Avatar
Drives: '07 Z4MC
That is..... INSANE!
At first, I didn't realize what I was looking at... Wow an LS1..Big deal. Then I counted the headers
      05-21-2013, 09:28 AM   #17
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
awesome... best of luck to you. subscribed
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      05-21-2013, 11:05 AM   #18
johanness
Drives: 2008 Z4MC
Holy crap! Did a Straight-8 cross your mind?
Good luck with everything. Sub'd
      06-13-2013, 12:52 PM   #19
Z@T
Pilot
Z@T's Avatar
Drives: M3, Vantage, 997, ModelX
Wow!! You took my dream and make it real!
I'm thinking since I bought my Z4 to put an LS engine in it.
Please keep us updated.
      06-13-2013, 02:15 PM   #20
v8z4
Once I get it finished, it should be easy to duplicate.
Chris
      06-13-2013, 03:25 PM   #21
philjw
Drives: 2011 M3 Coupe
This is insane. Very jealous
      06-19-2013, 12:13 PM   #22
Z4MGTO
Drives: '07 M Roadster/'06 GTO
This is by far one of the greatest concepts I've seen on this forum thus far. I wish you the best of luck on this and am super excited to see this project completed. My other car ('06 GTO) has an LS2 in it and it hauls ass, I can only imagine what this car is going to be like when its finished. Keep us posted on the status of this project as I cannot wait to see a finished product. Badass!!
/Subscribed
'07 ///M Roadster - Black Kidney Grills - 19" CSL Reps - Rogue El Diablo Exhaust - Black Roundels - Stubby - More to Come
'06 GTO - All Show, All Go
