02-11-2017, 08:35 PM | #89 |
Rep 194
Drives: 06 Z4M Roadster
Garage List 2006 Z4MR [0.00]
1972 For Sale Datsun [0.00] 2001 Dog/kayak haul ... [0.00] 2010 Daily Driver H ... [0.00] |
Love the clutch stop, now that I had a full afternoon to drive with it. Best $10 mod you can do. Though I have made an adjustment when the car would not start ( after it had started several times at the highest setting, which would allow it to start ) I then had the problem ONCE today, as I wanted to pull into the garage after a little detailing. Now I'm wondering if I just happen to be having a starter/solenoid issue ? Not even sure if this 06 HAS a solenoid ?
02-12-2017, 02:23 AM | #90 |
Rep 243
I just read through majority of this thread, how do you know where the best point to adjust the stop is at? It seems to me you could harm the clutch or trans if the clutch pedal isnt allowed to get completely engaged
02-12-2017, 07:37 AM | #91 |
Rep 194
Put key in accessory, hand push in clutch, you will hear a slight click ( there is a magnetic switch that will come "on" ), take 2 more turns screwing in ( away from clutch ), set the locking nut. Though you need to drive it to be sure. As stated, I've had to make 2 additional adjustments and am wondering if I've got a ghost in the machine with starter/solenoid.
02-12-2017, 06:39 PM | #92 |
Rep 2,704
Keep a wrench in the glove for the day when a high temperature causes the 2 turn in to not be enough due to expansion.
Ask me how I know!
02-13-2017, 11:09 AM | #93 |
Rep 194
I've had 2 occurrences now, where I've turned the key....and nothing. Both times it was after I had driven the car for a period of time, shut it off, restarted multiple times and then I can't pull into the garage, to put the car to bed ( 2 car covers ) I've read of others having this happen. Sat 81*, it was intermittent, so What is heating up. The bolt is getting appreciably longer ? Sounds strange. Bolts don't grow. The clutch ? Sure, it gets warmed up on ANY day, hot or cold. But is the point of engagement changing ? My 17mm opened end wrench is in my glovebox.
02-13-2017, 11:55 AM | #94 | |
Rep 2,704
02-15-2017, 03:06 PM | #95 | |
Rep 685
02-16-2017, 09:19 AM | #96 | |
Rep 19
Decent piece of hardware for $10 shipped. |
02-16-2017, 11:50 AM | #97 | |
Rep 685
02-16-2017, 12:21 PM | #98 |
Rep 19
Just a regular flat washer and nut.
02-16-2017, 03:43 PM | #100 |
Rep 685
02-16-2017, 06:48 PM | #101 |
Rep 1,543
Adjust the clutch magnetic switch to a higher point. (1cm) 5 min job. then you won't have to worry about not starting. it's been at least 5 years when I installed it, never a problem with heat or on the track.
02-17-2017, 04:34 AM | #102 |
Rep 194
OK, now I'm going to want to move mine. Do you mind sharing where The magnetic switch is and how to move it up. I felt like the engagement point was further out, but the switch was not letting me go out the far.
02-18-2017, 08:39 PM | #103 |
Rep 194
Going to search for the switch tomorrow, still having my intermittent non starting problems. Drove the car as a daily driver this week, as GF went into reverse, drunk at 3:00 AM to make a run for the boarder ON HER 30th BD....$3,700 in damage to the front of my gas sipping Honda Insight Hybrid....Put 300 miles on Z4M this week. If I don't get immediate start up, I let the clutch out, push in AGAIN and it starts. Not sure what is going on, but never happened before install of Clutch Stop.
Topless and getting my degree
02-19-2017, 12:47 AM | #104 | |
Rep 1,543
http://www.billswebspace.com/BMWZ4MM...stallation.htm HTHs.
02-19-2017, 05:45 AM | #105 |
Rep 194
Ahhhh, thank goodness for Bill. I've seen his VERY DETAILED page on other projects. I should have guessed he would have it all spelled out. Thanks for the direction.
02-19-2017, 10:46 AM | #106 |
Rep 2,866
If you guys are having issues with starting, all it means is you're not leaving enough margin for the magnetic clutch switch. Just leave another 1/8" to 1/4" when you hear the relay switch click! I had mine on for almost 6 years now - not a single starting issue (knock on wood).
02-19-2017, 06:39 PM | #107 |
Rep 11,667
.....or you could just code the switch out completely.
Euro cars don't have the switch & it's easy to code the module to the same setting.
02-27-2017, 12:38 PM | #108 |
Maniac
Rep 26
Drives: 2008 Z4M Roadster
So how does a travel limiter on my clutch pedal affect performance? Or the behaviour of the clutch as it doesn't have anything to do with it? Can't really understand it. And most of the time I'm driving on the limit, whether on track or canyon/mountain drives. What is it that you don't like and you're fixing with this?
03-04-2017, 08:54 PM | #109 |
Rep 194
It's the length of travel pushing in and then the length of travel out, till engagement. With the Stop Clutch, both of these are shortened, which is quicker. It's a nice precise point without the wasted travel.
03-05-2017, 06:16 AM | #110 | |
dances with roads
4722
Rep 4,096
