02-08-2017, 10:58 AM | #1 |
Rep 6
Z4M ride quality improvement
Hi guys,
new user from the UK here. I've had the Z4M as a daily driver for 2 years but recently my route has changed to one with particularly bad roads which is making the drive very bouncy/crashy. The car has only 30k miles so all the bushings etc are nice and tight and I had Bilstein B12 kit (shocks and Eibach springs) placed 6k miles ago which got rid of some of the slop from the OEM but I'd like to improve the quality of the ride especially small bump sensitivity some more. Could I get some recommendations? KW V3? Other coilover kits with road specific dampening? Not looking for a limousine comfort but my other car is a Nissan GTR which actually rides bumps better than the Z4M. Cheers. |
02-08-2017, 01:13 PM | #2 |
Rep 1,031
Hi and welcome.
I have Kw v3s and the ride quality improved greatly over stock. One place I noticed it the most was when doing a tail out slide. With stock suspension it would snap back but with the v3's it was a smoother transition. I don't remember much anymore of how stock felt as it's been many years but I do know that v3s soak up bumps better and the car transitions smoother. obviously also depends on how you set them up but general consensus is that they are better than stock.
Kazansky12.50 |
02-10-2017, 05:30 PM | #3 |
Rep 104
Wait 2 more months and I'll have a review of my setup from Fat Cat Motorsports (http://www.fatcatmotorsports.com/) for you. I have full confidence it will be near-magic, even with my "max track grip" design goal rather than a comfort-first setup.
If you want better ride quality compared to OEM, you'll need to find a setup that's not overdamped in rebound as many stock and aftermarket setups are (i.e. following a bump, wheel doesn't come back down as quickly and the suspension just "jacks down"). This is something best seen on a shock dyno plot, which are hard to come by unless you're getting your dampers custom valved. For comfort, I'd go with a softly sprung setup (275-300 lb-in front springs, sub-450-500 lb-in rear springs if you're staying with stock spring location), maximum possible suspension travel, and dampers that work with those spring rates. |
02-10-2017, 05:38 PM | #4 |
10847
Rep 4,892
I also have a kw v3 set (albeit on a non m but valving is the same) but I think they're fairly stiff... (much stiffer than oem)
Great for cornering though. Usually coilovers are stiffer than OEM as they are a performance product. That almost always means stiffer Do you drive on runflats or 19" wheels? I think with wheels&tyres the biggest gains on comfort can be made.
02-11-2017, 04:45 AM | #5 |
Rep 6
I was on Pilot Super Sports with standard Z4M wheels but have swapped to Pilot Sport 3's which has a slightly more forgiving ride due to more flexible sidewalls.
It's not so much about the high speed comfort. If anything the high speed compliance is much better with B12 than OEM. It's more the around town low to medium speed small bump sensitivity. I read that the V3's have quite good small bump sensitivity and the adjustability would obviously be useful. I think the best coilovers I have personally experienced for road comfort were Ohlins DFV, shame they don't make them for this platform. |
02-11-2017, 08:07 AM | #6 | |
Rep 3,004
Bilstein B12's....
My Bilstein B12's and Eibach Pro-Kit Springs arrived yesterday. Installation is scheduled later this month. The B12's are a fixed lowering amount of 20mm front and 10mm rear. What was your experience with the advertised lowering amount - was it appx this amount - any tire/wheel clearance issues - was your wheel alignment able to achieve the front amber OEM spec - or did you have to installed additional camber kits to achieve proper camber specs? Great to hear that performance handling improved - looking forward to your updates - regards.
Racerbruce
02-11-2017, 11:41 AM | #7 |
Rep 6
The lowering was as stated - 20mm 10mm with no rubbing. OEM geometry was achieved on a Hunter machine by the garage who fitted the suspension with no issues. For fast road driving (I haven't taken this car on track) the suspension really transformed the car from brake dive to pitching over undulations.
Hence why I'm a little cautious to change again unless it can improve the low speed ride. The B12 is a really great kit and would highly recommend it. |
02-11-2017, 03:39 PM | #8 |
Rep 3,004
Thank you Dudi -
I'm replacing the front control arms and upgrading them, and replacing the front control arm bushings and guide supports: T#21492 - 31122341828 - Genuine BMW Front Control Arm - Right - E46, Z4 - ZHP/Sport Upgrade - Genuine BMW - BMWGenuine BMW Front Control Arm - Right - E46, Z4 - ZHP/Sport Upgrade T#: 21492 1 $305.95 $305.95 T#54503 - 31308040203 - Genuine BMW Guide Support - 31308040203 - E85 - Genuine BMW - Genuine BMW Guide Support - 31308040203 - E85
Racerbruce
02-14-2017, 11:29 AM | #9 | |
Rep 209
Drives: Z4M roadster
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
02-19-2017, 11:51 AM | #10 | |
Rep 6
could you tell me whether you have had to cut any internal trim to access the rear upper adjusters. From what I can see KW have revised the adjuster wheels and locations but can't get a certain answer as to whether they have for the Z4M application. I'm pretty much set on going for them so will be ordering in the next few days. |
02-20-2017, 08:34 AM | #11 | |
Rep 274
I purchased and installed KWV3 in August 2015 and didn't need to cut any internal trim to access the adjusters, not sure if they've changed since then ?Really happy with the ride quality especially since I'm lowered, although I think lighter wheels improved small bump comfort quite a bit too. I don't think these Zeds will ever be super comfy since we're sitting on top of the rear axle. |
04-18-2017, 05:34 PM | #13 | |
Rep 355
I'll see if i can find it.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
04-26-2017, 03:13 AM | #14 |
Rep 6
Just to bump this thread and get further opinion.
Ordered a set of V3's but the supplier sent a set for a normal Z4 not a Z4M. In the meantime a set of KW Clubsport have come available for less money than I will be paying for V3's. Any daily drivers on Clubsports out there? Will the ride be significantly firmer than V3's? |
05-03-2017, 04:08 PM | #15 | |
Rep 104
I asked for a soft, "max grip" track day set up to be used with RE71R / streetable R-comp tires (but no significant downforce) and Shaikh at FCM more than delivered. The Z4M now much more composed - more grip everywhere on the exact same set of tires, car is much less upset by track curbs and on-road potholes, way less harshness from highway expansion joints / sharp bumps, even with monoball rear shock mounts and race camber plates. The suspension also recovers faster from successive bumps / dips, so even as the speeds increase, it just keeps on soaking up road imperfections. Overall, I'm very happy with the setup so far as it achieves massively improved comfort and ride quality despite being designed primarily to improve track grip. The spec: FCM-revalved non-adjustable Bilsteins with flat ride / ripple reducer / FCM's "kerb blow off" tech (started with the off-the-shelf H&R coilover kit), 336 / 616 lb-in F/R linear Swift springs, Vorshlag race camber plates, RE monoball rear shock mounts. |
06-20-2017, 06:02 PM | #16 | |
Rep 209
I am seriously considering an FCM setup for my roadster - would you mind PM-ing me with approx all-in cost, for comparison purposes. Thanks Stuart
06-21-2017, 12:28 PM | #17 | |
Rep 104
I kept ride height close to OEM to better manage speed bumps, random troughs / ledges / potholes, and badly graded approaches. I've been very pleased with my setup so far, it's been a no-compromise improvement in both grip level and comfort. |
06-21-2017, 01:02 PM | #18 | ||
Rep 1,543
TIA,
