      05-25-2011, 07:06 PM   #1
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Can Z4M DSC be turned completely off?
As the title says...I'm trying to prep the car for it's first autocross and like my E46, I wanted to see if I could turn the DSC completely off (buy holding it for 5 seconds for the DSC light and yellow brake like to come on).
Oddly enough...the yellow brake light never came on when I pushed and held the DSC light...what gives?
I don't want to have DSC on...as it usually stops the tires from rotating.
Can DSC be turned completely off or can you just press it once and it can only extend the limits?
      05-25-2011, 07:11 PM   #2
O-cha
O-cha's Avatar
218
Drives: Mcoupe
umm pressing it once does turn it off. Whatever problem you;re having is something else. The one thing that does still stay on is the trail braking feature which stabilizes the car in high speed sweepers if you brake and unsettle the rear (preventing an oversteer spin)
      05-25-2011, 07:12 PM   #3
r4gs
Viper Driver
Singapore
36
Drives: F-16
the m's only have dsc, so simply pressing the button once deactivates dsc entirely. the standard z4's have dtc on top of dsc, which is disabled with a single press of the button. dsc is subsequently deactivated entirely by pressing and holding the button in a standard z4.
      05-25-2011, 07:25 PM   #4
Kgolf31
Kgolf31's Avatar
460
Sorry to be acting stupid...but it didn't do this on my E46. Hench why the question came up.
Roger. Thanks for the answer. It all makes sense now
      05-25-2011, 10:53 PM   #5
Tonybest
Enrollment Officer
Tonybest's Avatar
Drives: 997.2 Porsche C4S
Just adding an extra answer to a question already answered...
DSC is either ON or OFF so no 5 second holding. This on a z4M
      05-25-2011, 11:21 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Funny thing is, coming from a z4 3.0, I was wondering if the z4M I first test drove had a broken stability control system, since it wouldn't go into the intermediate mode
      05-26-2011, 08:44 PM   #7
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
lol I remember the first time I tracked the Z4M. I was all worried that it would be too much for me to handle. Since it was new to me, I wanted to take it easy and keep DSC on...
One lap later, I turned DSC off and have never tracked with it on ever again
      05-31-2011, 09:39 PM   #8
Kgolf31
Kgolf31's Avatar
460
I wanted to do that...but then I'd want to keep it like that.
I turned it off from the beginning and kept it like that, takes some times use to getting the power down (I used to autocross a 325xi), but it's so fun!
Here is the first run someone got from behind me....dropped the clutch alittle too high in RPM and some sand at the start gets you this. Took too much speed into the cones and knocked a set down when I got alittle loose, whoops
(Ignore the cone hits...I didn't know where my front right end is yet!)
      07-06-2011, 08:22 AM   #9
MIKe86
Drives: 90 332is
V8 behind you? Sounded pretty grunty.
Looks like you were having some fun.
      07-06-2011, 08:46 AM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
...... The one thing that does still stay on is the trail braking feature which stabilizes the car in high speed sweepers if you brake and unsettle the rear (preventing an oversteer spin)
^ missed this when you posted it.
Thanks, I did not know that.
Everything I've seen posted before & the M supplementary manual just said it was completely off.
      07-07-2011, 07:25 PM   #11
Kgolf31
Kgolf31's Avatar
460
325i. For the first autocross it wasn't too bad.
4th Autocross on the car and still learning how to NOT understeer and oversteer. I've seem to do it every time it's my first run, lol
Certainly seems completely off.
